Activity Forums VEGAS Pro Vegas- displaying a portion of a larger clip in a smaller project
  • Vegas- displaying a portion of a larger clip in a smaller project
    Posted by Byron Nelson on October 27, 2019 at 6:46 pm
    Dear Forum,
    I have a 1920 x 1080 video. I want to apply a hitfilm action camera correction to it, anchoring it at the corners. Then, I want to only display the middle 1440 x 720 of that image, producing a rectangular image with the distorted corners cut off. Something like this is relatively simple to do in FXhome’s Hitfilm, but I’m beginning to believe I can’t do this in Vegas.
    In that line of thought, is there even a way to have, for example, a 1440 x 720 project and load a 1920×1080 video onto the timeline, but only display the middle 1440 x 720 pixels of that larger clip? I feel like I must be missing/overlooking something fundamentally simple.
    Byron Nelson replied 6 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Paul Berk
    October 27, 2019 at 11:42 pm
    >>I have a 1920 x 1080 video. I want to apply a hitfilm action camera correction to it, anchoring it at >>the corners. Then, I want to only display the middle 1440 x 720 of that image
    Then make your project properties 1920 x 1080. Then use Vegas pan/crop to crop the hit film video to 1440 x 720. That should work.
  • Byron Nelson
    October 28, 2019 at 2:51 pm
    Thanks for the reply, but I still can’s achieve my goal.
    Here is a shot of the original video.
    Here is what I am hoping to achieve-
    I want to output a video of the dimensions that are marked by the red center rectangle. I essentially want to have a video with the distorted corners cut off without letterboxing.
    I think I am following the steps you outlined. I use the 1920×1080 project properties. Then I pan/crop down to size and I obtain this-
    Then I distort, and I achieve the following
    Which is a distortion of the cropped image. Either with stretching the image in the pan/crop settings or not the result is the distortion is of the cropped image.
    So, I reversed order of the distort and crop, and tried to distort first, then crop.
    And that simply came out bizzare regardless.
    Hitfilm seems to treat the video as a canvas with the project properties defining a window looking onto that canvas such that they can be different sizes. Their Pan/crop (transform controls) moves and sizes the canvas where you can fit it into the window as you wish.
    For instance, putting the bigger video into a project with a smaller window only shows me a portion of that canvas. Then, when I distort the canvas, I bring in elements that I want into the window, leaving the corners outside.
    I can’t quite intuit what it is that Vegas does.
    Byron
  • Francois Pénzes
    October 28, 2019 at 8:54 pm
    Hi Byron
    Just so I get what you’re aiming for, can you post an example made with Hitfilm ?
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Edward Troxel
    October 29, 2019 at 11:43 am
    What if you move the distort effect to the left of “Pan/Crop”?
    Edward Troxel
  • Byron Nelson
    October 30, 2019 at 12:51 pm
    What I get then is in the second to last picture
  • Byron Nelson
    October 30, 2019 at 12:52 pm
    .. I meant the last picture, not second to last.
  • Byron Nelson
    October 30, 2019 at 1:18 pm
    Hello Francois,
    I have a 1920 x 1080 video with fisheye from an action camera. I want to correct the fisheye and output a rectangular video that is just the un-distorted portion of the fisheye-corrected video.
    So, I have this video that I want corrected..
    so that the final video looks like this…
    I loaded the original 1080p video, then corrected it, and used the corrected image to determine the width and height of the final video that I would need (that needed to grab the rectangle in the original post). It was 1550 x 720 .
    I set my project to those dimensions.
    Next, I loaded the 1920×1080 clip. Notice how the clip is not scaled to fit into the project. The project simply works as a window on to larger image.
    So that when I apply the correction to the video, it scales down and fits my project window…
    Then, I can export a 1550 x 720 undistorted (relatively) video.
    best,
    Byron
