Activity › Forums › VEGAS Pro › Vegas Crash Unmanaged Exception 0xc0000005 Before Splash Screen
  • Vegas Crash Unmanaged Exception 0xc0000005 Before Splash Screen
    Posted by Chris Rogers on January 18, 2015 at 10:55 pm
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 310) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Fault Address: 0x00007FF687049E00
    Fault Offset: 0x0000000000819E00
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 310) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2014-04-29 (Tue Apr 29) 20:38:06
    I haven’t used the program in a few months, and when I went to fire it up today I get an immediate Problem Report screen – not even the Splash Screen shows up. I have tried disabling my video card and running as administrator, but I cannot get anything besides the Problem Report.
    Norman Black replied 11 years, 8 months ago 3 Members · 2 Replies
  • John Rofrano
    January 19, 2015 at 11:54 am
    [Chris Rogers] “Application Version: Version 13.0 (Build 310) 64-bit”
    The latest build is 428. Try updating and see if that cleans things out and gets you going again. If not, I would completely uninstall and re-install. It’s really hard to say what might be going on. You might and to contact Sony.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Norman Black
    January 21, 2015 at 4:02 am
    Try starting Vegas while holding the Ctrl+Shift keys down. That will reset Vegas to default preferences. Also answer yes to the option to delete saved data.
