Activity › Forums › VEGAS Pro › Vegas Codecs (Where to find)
  • Vegas Codecs (Where to find)
    Posted by Laura Kozikowski on February 3, 2010 at 1:15 am
    Alright, I had previously been using Vegas on XP with the Community Codec pack and things were going fine, but after updating to 7 I am missing some codecs. I reinstalled the CC pack but no luck, so I uninstalled it and tried K-Lite, again no luck.
    When dragging (or importing) video files, I am missing the audio. Gspot says it’s mp4a: MPEG-4 AAC LC. Have been looking everywhere with no luck. Any ideas? Thanks…
    Joe Perry replied 16 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    February 3, 2010 at 12:20 pm
    What is the file type? Vegas has separate decoders that handle each file type. Even if you have the codec installed, if the decoder is not expecting that codec to be in the file type then it won’t be able to decode it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Laura Kozikowski
    February 3, 2010 at 8:17 pm
    Well I’ve used Youtube Downloader to grab some files off YouTube. They are .mp4 files. Gspot says:
    mp42: MP4 v2 [ISO 14496-14]
    – isom: MP4 Base Media v1 [IS0 14496-12:2003]
    – avc1: MP4 Base w/ AVC ext [ISO 14496-12:2005]
    Under audio codecs it lists:
    mp4a: MPEG-4 AAC LC
    Under video codecs it lists:
    avc1
    when I import/drag it into Vegas Pro 8.0, I’m left without the audio.
    I’m a little new to the codecs, but I’m following everything said you said. Is there a way to change the association, if you will, so that Sony is aware it has the proper codec and tell it to look within the proper format? If that is the case, where I can find the codec I need and how do I go about changing Vegas?
    If that isn’t possible, what would be the best way (and best format) to convert these files into. Everything that I have tried that Vegas allows, ends up with very very poor quality. Of course, I’d prefer to not have to convert at all, but whatever needs to be done.
    Please let me know if you need any more information.
    Thanks 🙂
  • Mike Kujbida
    February 3, 2010 at 8:26 pm
    Are you using the latest version of Vegas 8 (it’s 8.0c)?
    I just did a download using the same software, ran it through GSpot, got the same results, dropped it on my Vegas Pro 8 timeline and both video and audio were there.
  • Laura Kozikowski
    February 3, 2010 at 8:31 pm
    Vegas says…
    Version 8 (Build 144) C.2007
  • Mike Kujbida
    February 3, 2010 at 8:55 pm
    That’s very strange.
    The only codec pack I have installed on this machine is ffdshow.
    You could try installing it and see if it helps.
    It’s a trusted piece of software from a trusted site so there’s no worries about corrupting anything.
  • Laura Kozikowski
    February 3, 2010 at 9:28 pm
    No change 🙁
    Is there a way to see what codecs Vegas has associated with what formats? Then at least it could be determined if it’s an issue with Vegas recognizing it or with the codec itself not being found.
  • Joe Perry
    February 3, 2010 at 11:14 pm
    Unless I missed something – I don’t think anyone has answered your question of “is there a place where you could see which codec is registered or missing”. Is it a registry location? Is there a place where you can see which codec’s you have?
    I get different results on different machines using the same Vegas versions, so I know it has to do with what software is loaded and recognized by Vegas. I too am having the same problem and have not solved it yet. Any help would be appreciated
  • Joe Perry
    February 3, 2010 at 11:25 pm
    HD – H.264 Video (*.mp4) – video – no audio
    HD – MPEG-4 Movie(*.mp4) – video – no audio
    D WMV Video (*.wmv) – video and audio
