Activity Forums VEGAS Pro vegas changes mpg to m2v
  • vegas changes mpg to m2v
    Posted by Wayne Grauel on July 3, 2007 at 4:43 pm
    Why does Vagas change some of my renders to an M2v (or what ever it is) format.
    solution is as simple as renaming it back to mpg.. but it is still a pain!
    Thanks wayne
    Brian Sinks replied 19 years, 2 months ago 4 Members · 6 Replies
  • Mike Kujbida
    July 3, 2007 at 5:20 pm
    My guess is that you’ve accidentally used the
    DVD NTSC video stream template instead of the
    DVD Architect NTSC video stream template.
    Selecting the former will give you an M2V file instead of the MPEG-2 file you get with the latter.
  • Wayne Grauel
    July 5, 2007 at 9:08 am
    Mike, basically i use the DVD Architect settings and modify the bit rates as required. This one was 2.15 with about 50 chapters.
    The render also did not include the chapters…hmmmm
    and it was also 3.99 gigs so it says.. DVD Arch. said it was well over 4.7 so I went back and bumped the bit rates on the lower end slightly… the file rendered with adequate room, it did not change the file name and the project markers were there…
    So…. evidently, maybe the software was doing this..
    But thanks for your advise
    about the MPEG DVD. thats what I thought.. but wanted to see is anyone had any specifics… thanks again.. it was appreciated.
    Wayne
  • Mike Kujbida
    July 5, 2007 at 1:36 pm
    That happens to me sometimes too. I’m sure there’s a reason but I’ve never been able to figure out why 🙂
    When that happens, I can usually get the markers by clicking the Load Markers icon in DVDA. If that still doesn’t work, then it’s time to add them manually 🙁
    …and it was also 3.99 gigs so it says.. DVD Arch. said it was well over 4.7″
    As long as you know that what you’re feeding DVDA is under the limit, ignore any warnings that the file is too large.
    DVDA has a long history of incorrectly reporting file sizes.
  • Edward Troxel
    July 5, 2007 at 2:37 pm
    The markers are stored in a separate file from the video. The markers are in the .SFL file. If you move the rendered file or delete the .sfl file, it won’t find the markers.
    Edward Troxel
    JETDV Scripts
  • Brian Sinks
    July 5, 2007 at 6:44 pm
    Per the size issue. DVDA is showing the current “actual” size. Unfortunately, there is aspects likes your menu(s) that have not been compressed/rendered yet. Note before you do anything to a new project in DVDA it shows you already have something like 500MB which if you rendered it would only be a couple MBs. In Vegas, I’ve always rendered just a little under the calculated average (5-10%) so I have a little DVD real estate to play with. Plus, I’ve also found it’s a good idea to leave some fingerprint room on the outside of the disc.
    Brian Sinks
    IN1ACCORD Productions
    Tulsa, Oklahoma
  • Brian Sinks
    July 5, 2007 at 6:47 pm
    “Plus, I’ve also found it’s a good idea to leave some fingerprint room on the outside of the disc.”
    Sorry, what I meant to say was “edge” of the disc instead of “outside.”
    Brian Sinks
    Tulsa, Oklahoma
