Activity Forums VEGAS Pro Vegas causing audio to peak very slightly
  • Vegas causing audio to peak very slightly
    Posted by Austin Bauer on February 21, 2022 at 1:03 pm
    I work for a streamer that has a very sensitive ear when it comes to audio peaking and he’s been complaining about it in my videos recently. For some reason, the audio peaks slightly in Vegas Pro 17 and 19. But NOT in other software like DaVinci Resolve.
    Rendered in DaVinci: https://www.youtube.com/watch?v=jJgNq9CZF-c
    Rendered in Vegas 19: https://www.youtube.com/watch?v=aIHH7dF5Pnk
    I need a solution to this. Because editing in DaVinci isn’t an option since it causes a severe drop in visual quality for some reason and I don’t want to switch to software I’m not used to. Does anyone have a solution?
    Edward Troxel replied 4 years, 6 months ago 2 Members · 3 Replies
  • Edward Troxel
    February 23, 2022 at 11:29 pm
    What if you use a slight compressor to keep it from peaking.
  • Austin Bauer
    February 23, 2022 at 11:38 pm
    How do I do that?
  • Edward Troxel
    February 24, 2022 at 3:46 pm
    1. click on “Fx” on the audio track. The compressor should already be there so select it. and then select an appropriate preset or adjust the settings to suit.
