Activity Forums VEGAS Pro Vegas can’t see gh5s clips
  • Vegas can’t see gh5s clips
    Posted by Sandra Marszałek on May 24, 2018 at 1:41 pm
    Hi everyone
    I got some clips from gh5s.
    I’ve tried to put them on the timeline and for those that were recorded as a slow motion everything works fine but for those in normal speed I see green screen and can hear the audio.
    I can open them correctly only in VLC Media Player
    Those in slow motion
    Normal speed info
    My spec
    Vegas Pro 13
    Win 8.1
    That’s the first time I have problems with those clips. Do I miss any new codec or something?
    John Rofrano replied 8 years, 3 months ago 4 Members · 4 Replies
  • Mike Kujbida
    May 24, 2018 at 1:54 pm
    From the Vegas Creative Software forum:
    Some formats it shoots will open correctly in VP13/14 but 4K 10-bit 4:2:2 AVC files weren’t supported until VP15.
  • Sandra Marszałek
    May 24, 2018 at 1:58 pm
    But those are normal FHD clips not 4K :/
  • Russ Froze
    May 31, 2018 at 9:51 pm
    Hello, are the file extensions .mp4 or .mov. If .mov you may need to have QuickTime installed in order for Vegas to access the files.
    Russ
  • John Rofrano
    June 3, 2018 at 1:31 pm
    [Mike Kujbida] “Some formats it shoots will open correctly in VP13/14 but 4K 10-bit 4:2:2 AVC files weren’t supported until VP15.”
    [Sandra Marszałek] “But those are normal FHD clips not 4K :/”
    Yes but you are still shooting 4:2:2 AVC so maybe that is enough to make it not work? Look at the specs that you gave us in your original post:
    Slow motion: (works)
    Format profile: High@L5
    Normal speed: (doesn’t work)
    Format profile: 4:2:2@L4.2
    You are shooting 4:2:2@L4.2 profile so as Mike suggests this might be a case of using 2016 software with a 2018 camera. You can’t expect old software like Vegas Pro 13 to always work with new cameras.
    This is easy enough to figure out… I would download the trial of Vegas Pro 15 and and if it works with these files then you’ve found your solution (upgrade your software).
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
