Activity Forums VEGAS Pro Vegas can’t handle variable bit audio?
  • Vegas can’t handle variable bit audio?
    Posted by John Riker on October 9, 2010 at 11:55 pm
    I have a slew of video files I am trying to put onto Bluray. Using Vegas to convert them appropriately. Issue I am seeing is when the audio is CBR in the container the audio and video are the same length. When the audio is VBR it shows as longer in Vegas. If I play the file in WMP everything is cool. What is Vegas doing when it sees a variable bitrate audio file? Can’t it handle it properly?
    Thanks.
    JR
    John Rofrano replied 15 years, 11 months ago 2 Members · 1 Reply
  • John Rofrano
    October 10, 2010 at 1:33 am
    [John Riker] “What is Vegas doing when it sees a variable bitrate audio file? Can’t it handle it properly?”
    For certain formats, No. Just because you can mix and match different video and audio formats in a container doesn’t mean that Vegas supports all possible combinations. If CBR works, then use another program like AviDemux or VirtualDub to convert the audio to CBR.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
