Activity Forums VEGAS Pro Vegas Audio Render Problem
  • Vegas Audio Render Problem
    Posted by Lewis Nabulsi on August 8, 2011 at 1:09 pm
    Hi im very new to this forum but i will give as much information as possible about the problem…
    This is my video that i put on youtube which is just illustrating the problem with the audio:
    https://www.youtube.com/watch?v=hTedjq_ELqY
    As you can hear, the mp3 track (the original song) keeps cutting in and out however on my project in vegas this does not happen and besides the pre render lag, everything is silky smooth.
    My rendering settings are:
    Video:
    AVC HD 1920×1080
    Frame Rate : 29.970
    Bit Rate: 15,000,000
    Audio
    192 Kbps, 48,000Hz 24 Bit Sterio, AC3
    VIDEO fORMAT MPEG 2 (.m2ts)
    Could anybody give me some stable audio settings that could prevent this problem from happening as i have rendered the same vid 3 times now thinking it was just being a nuisense with me. Now it’s getting ridicolous… Like i said, there is no problem with the project but their is a problem post rendered.
    Lewis Nabulsi replied 15 years, 1 month ago 2 Members · 3 Replies
  • Stephen Mann
    August 8, 2011 at 3:57 pm
    You are likely seeing the encoder at You Tube reacting to your way-too hot audio.
    Have you tried applying the limiter in the audio event F/X?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Lewis Nabulsi
    August 8, 2011 at 6:59 pm
    Hi thank you for your reply,
    i have been messing around with the settings and have made it so that the master volume on both mp3 tracks are not clipping.——->
    I am using Vegas Pro 10 and i dont think their is a plugin for the limiter but i have done a few tweaks to the gains and according to the master volume, nothing is in the red.
    These are just some other settings on my project:
    Oh and for a side note, the jittery audio is a problem after render and not just when it’s uploaded to youtube.
    Are these settings alright, what would you reccommend?
  • Lewis Nabulsi
    August 9, 2011 at 5:21 pm
    Just a quick update, i misunderstood the term limiter but guessed you meant the compressor, anyway this is the project now, i do think their is an improvment——–>
    Tell me what you think Steve and should i go and render it?
