Activity Forums VEGAS Pro Vegas and TMPGEnc 3 AC3 Sound
  • Vegas and TMPGEnc 3 AC3 Sound
    Posted by Rendez3k on July 26, 2005 at 9:36 am
    If I encode any videos with TMPGEnc 3 and use the AC-3 plugin sound option, Sony Vegas 6 will only recognize the video – is there anyway round this? The issue also occurs with imported DVD footage from a Sony DVD cam. Many thanks.
    :: http://www.rendez.net
    Edward Troxel replied 21 years, 2 months ago 2 Members · 3 Replies
  • Edward Troxel
    July 26, 2005 at 3:43 pm
    Vegas 6 will not read AC3 audio. You will need to convert it to something Vegas 6 can read (like WAV). Same is true with your camera footage – the audio is AC3 and needs to be converted to something else.
    Why are you giving Vegas 6 files encoded in TMPGenc? MPEG2 is NOT a good editing format.
    Edward Troxel
    JETDV Scripts
  • Rendez3k
    July 26, 2005 at 3:48 pm
    The TMPGEnc video was more of a test. The main issue started when I got the DVD files off the camera and it had AC3 audio. Its the files from the camera I really need to edit!
  • Edward Troxel
    July 26, 2005 at 4:36 pm
    Either use some program to convert it to DV-AVI or capture out the analog output of the camera through a convertor such as the Canopus ADVC-100 into a standard DV-AVI file.
    In all honesty, you would be better off trading it in on a MiniDV camera.
    Edward Troxel
    JETDV Scripts
