Activity Forums VEGAS Pro Vegas and RAIDS?
  • Vegas and RAIDS?
    Posted by Ken Bennett on July 26, 2010 at 4:05 am
    Should I be capturing data for Vegas Pro to a RAID or a simple single drive? I’ve always used RAIDs for video capture, edit and playback.
    Good, bad, pros, cons?
    Thanks.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Danny Hays replied 16 years, 1 month ago 3 Members · 2 Replies
  • Norman Willis
    July 26, 2010 at 4:11 am
    My C:\ and D:\ are both RAID 0 with two disks each.
    I was told that it does very little to have C:\ in RAID 0, so I plan to make C:\ a standalone single drive, and put D:\ in RAID 5, with three disks (and also back that up externally). That way, if anything bad happens, I don’t lose data.
    I was told to render to D:\Temp, and it seems to work.
    Norman Willis
    http://www.nazareneisrael.org
  • Danny Hays
    July 26, 2010 at 4:21 pm
    I’ve been using Vegas, even with HDV for years on single drives, mostly 7200 rpm, but it’ll even work with external 5400 rpm usb2 drives, just a little slow. Now if you are capturing uncompressed video you will defenitly need a raid 0 array. Danny Hays
