Vegas and .net framework 1.1
Posted by Joao Carlos schwalbach on March 16, 2006 at 5:24 amWhen trying to install vegas, it asks for the .net framework 1.1
Since I donJoao Carlos schwalbach replied 20 years, 6 months ago 3 Members · 3 Replies -
Jeremy Rochefort
March 16, 2006 at 9:32 amYou will also require the .Net Service Pack 1 which can be downloaded from here:
https://www.microsoft.com/downloads/details.aspx?familyid=a8f5654f-088e-40b2-bbdb-a83353618b38&displaylang=enCheers
Jeremy
MJ Productions
Edward Troxel
March 16, 2006 at 2:56 pmVegas 4 required .NET 1.0 (or newer – i.e. 1.1 sp 1)
Vegas 5 requires .NET 1.1 (or newer – i.e. 1.1 sp 1)
Vegas 6 requires .NET 1.1 SP 1Note that .NET 2.0 is totally different and cannot be used as a substitute. However, you CAN have .NET 1.1 SP1 and .NET 2.0 both installed at the same time.
March 17, 2006 at 5:45 amThanks…sometimes it helps when one reads the messages carefully 🙂
Vegas
