Activity Forums VEGAS Pro Vegas and Final Cut Pro – friends or enemies?
  • Vegas and Final Cut Pro – friends or enemies?
    Posted by Tim Gibbons on July 5, 2007 at 11:02 pm
    Hello!
    I’m looking to transfer some HDCam footage into a codec that a Vegas editor can use. Unfortunately he doesn’t have a capture card or an HDCam deck. I do have a friend who is willing to do it but he can only capture using Final Cut Pro. I want him to capture the footage onto an external drive into a DVCPro HD codec. Does anyone know if Vegas can read a quicktime file crated in FCP in this codec? Do Vegas and FCP play nice?
    Tim
    Tim Gibbons replied 19 years, 1 month ago 4 Members · 4 Replies
  • Seth Estrada
    July 6, 2007 at 12:35 am
    Yes, they ‘play nice’ in most areas but DVCPRO, in general, is not one of them. DVCPRO HD is not something that Vegas 7e has support for out of the box. (Nobody’s perfect; FCP had horrible HDV support for a painfully long time) But he can use Raylight, a non-free third party tool, to put DVCPRO HD into an ‘AVI wrapper’ and then edit in Vegas. My big questions are what is your final delivery format? And do you need to do heavy color correction/post processing/VFX?
    -seth
    “Oh be wise, what can I say more?”
  • Mike Kujbida
    July 6, 2007 at 1:06 am
    “Does anyone know if Vegas can read a quicktime file created in FCP in this codec?”
    I did a search of “DVCPro HD” on the Sony Vegas forum and came up with the following that may be helpful.
    Take a look at the products from DVFilm, specifically Raylight & Raylight Decoder.
    Demo versions of each are available.
    Good luck with it and please let us know if it works.
  • Marcus Van bavel
    July 6, 2007 at 1:41 am
    [Mike Kujbida] ” did a search of “DVCPro HD” on the Sony Vegas forum and came up with the following that may be helpful.
    Good luck with it and please let us know if it works.”
    Correct, Raylight DECODER will allow import and editing of
    DVCPROHD quicktimes in Vegas.
    For going the other direction, you would need the other
    Raylight product, DVFilm Raylight, and export a Raylight
    AVI from vegas. This can then be converted into an MXF file with
    P2 Maker (a utility included with DVFilm Raylight). The MXF
    file is then importable into FCP.
  • Tim Gibbons
    July 12, 2007 at 11:53 pm
    Thanks Guys,
    Your advice made me realize there is no easy solution. I ended up having a friend just dub the tapes to DVCam directly from a HDCam deck. Can’t wait for the 2/3″ XDCam HD camera. That’ll make everything easier.
    Tim
