vegas 9/particle illusion
Posted by Fred Bargnare on August 11, 2009 at 8:15 pmcan I use particle illusion with vegas 9, if so how can I do it.
Peter Friend replied 17 years, 1 month ago 3 Members · 3 Replies -
Adam Rose esq.
August 11, 2009 at 9:34 pmhave to create effect in PI, then render out with alpha channel, and bring into vegas as clip
change media properties of clip via right click, to include alpha channel, if it doesn’t immediately show alpha
Fred Bargnare
August 11, 2009 at 10:34 pmwow that sounds difficult maybe cause Im new to PI and vegas 9 Im use to pinnacle 12 is that the only way
Peter Friend
August 12, 2009 at 9:03 pmAdam is correct. The two packages have no interface as such, but PI output is completely compatible with Vegas (or any other NLE). The bit about alpha channels only applies if you want to add the PI output on top of another video stream e.g. add an explosion to a video clip. The only ‘gotcha’ I’ve found is that only some codecs allow alpha channel info – if you pick a codec that doesn’t, PI will grey out the alpha channel tick box.
