Activity Forums VEGAS Pro Vegas 9b Renders Faster Than 10a
  • Vegas 9b Renders Faster Than 10a
    Posted by Sam Caino on October 14, 2010 at 6:39 am
    Using the trial of 10a, I rendered out a clip in the Sony AVC .mp4 “Internet 640×480-30p” template. The 1 minute clip took 1:39 to render.
    Using the exact same render settings (I checked multiple times) and the exact same 1 minute clip, the rendering only took 1:18 in Vegas 9b.
    I did the same test using an .mpg2 output and 9b took 50 seconds to render while 10a took 60 seconds.
    This test was done on an HP xw8200, Dual 3.6 cpu with 3.5 gigs of ram. I realize this is an older machine, but the fact still stands. Vegas 9b can render faster than 10a when the circumstances are identical.
    I once upgraded to 9e and noticed a slowdown in render times from 9e to 9b. I immediately reverted back to 9b because render time is everything in my workflow. I was hoping 10 would address this, but unless anyone has some insight, it apparently doesn’t.
    I thought this was worth mentioning since most comparisons people will be making will be between 9e and 10.
    Secondly – does anyone else rely on Network Rendering for their workflow? It appears Sony has done away with it in 10. We really can’t do our jobs without it in my department.
    Dave Lozinski replied 15 years, 1 month ago 2 Members · 1 Reply
  • Dave Lozinski
    August 3, 2011 at 7:20 am
    Hi there,
    In terms of the rendering speed, try it now with Vegas 10e. It takes advantage of GPUs if you have any. Before this there were apparently issues with rendering using the Sony AVHCD plugin.
    Sorry but I can’t help you with the network rendering. That’s not the best way to do things because rendering across a network adds significant lag time.
    You’re best to render locally and then copy the movie file to your final destination.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
