Activity › Forums › VEGAS Pro › Vegas 9.0 64-bit crash on “Render As”
  • Vegas 9.0 64-bit crash on “Render As”
    Posted by Richard Penna on January 23, 2010 at 9:05 pm
    I have a Windows 7 64-bit system and Vegas 9.0c 64-bit.
    Project loads fine, but when I click File > Render As, the program immediately crashes with a problem report that says the following:
    Extra Information
    File: C:\Users\Richard\AppData\Local\Sony\Vegas Pro\9.0\dx_video_grovel_x64.log
    File: C:\Users\Richard\AppData\Local\Sony\Vegas Pro\9.0\dx_grovel_x64.log
    File: D:\Own Stuff\DV & HD\USA HD\Scenes\Zion x64.veg
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0c (Build 895) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554\MSVCR90.dll
    Fault Address: 0x0000000061B6E210
    Fault Offset: 0x000000000001E210
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Process Version: Version 9.0c (Build 895) 64-bit
    Process Description: Vegas Pro
    The logs also contain these lines:
    ERROR Sony.MediaSoftware.DeviceExp.Controller [(null)] – SmpteDrop
    ERROR Sony.MediaSoftware.XDCAMExp.Controller [(null)] – SmpteDrop
    Has anyone come across this before? It also happens in 8.0c 64-bit.
    I’m also getting the out of memory error in 32 bit versions, but that’s for another day.
    Many thanks for any help received 🙂
    Ariel Zion replied 15 years, 12 months ago 4 Members · 4 Replies
  • Phil Mcgeary
    May 29, 2010 at 1:02 am
    I just upgraded to Vegas Pro 9 64bit from Vegas 7. I also have a Win& 64bit machine. Same issue. Found any solutions besides returning to 32 bit?
  • Mike Kujbida
    May 29, 2010 at 2:04 am
    Richard, you need to send error logs to Sony as they’re the only ones who can decipher them.
  • Richard Penna
    October 2, 2010 at 1:44 am
    I found a solution. Find your Application Data folder (‘C:\Users\\AppData\Roaming\Sony\File Templates’ on Windows 7) and rename the ‘File Templates’ folder then restart Vegas. The problem instantly went away for me.
  • Ariel Zion
    October 4, 2010 at 4:03 am
    Can you go to my second thread and read the information to see if you know how to get around the problem without me having to re-install the 32 bit version of svp 9.0c ?
    Ariel Zion
