Activity Forums VEGAS Pro Vegas 9 set-up
  • Vegas 9 set-up
    Posted by Don Hutcheson on February 22, 2010 at 4:26 pm
    I am Running Vegas 9 on a Quad-core 64-bit computer with 4G memory and instead of putting a new video file on the timeline almost immediately (like Vegas 6 and 8 did), it takes 4 or 5 minutes to get the file loaded. Also, it doesn’t display the actual video (thumbnails) all across the timeline like previous versions. All I see is a “thumbnail” every ten minutes or so, then a gray box the rest of the time. I can’t see to edit frames. Is there a setting I can change to get the same frame-by-frame “thumbnail” visualization like the previous versions?
    Thank you,
    Don
    Hutch
    Mark Prebonich replied 16 years, 6 months ago 4 Members · 4 Replies
  • Theo Van laar
    February 22, 2010 at 5:02 pm
    ‘ Is there a setting I can change to get the same frame-by-frame “thumbnail” visualization like the previous versions?’
    View – Active Take Information
    Theo
  • Mike Kujbida
    February 22, 2010 at 5:17 pm
    Theo, I think what Don is referring to is found under Options – Prefs – Video – Thumbnails to show in video events.
    The default used to be All but was changed in Vegas Pro 9.
    It’s quite easy to change it to whatever you want.
  • Don Hutcheson
    February 22, 2010 at 9:34 pm
    That was exactly it.
    Thank you,
    Don
    Hutch
  • Mark Prebonich
    February 24, 2010 at 6:07 am
    ‘The default used to be All but was changed in Vegas Pro 9.’
    Do you know why this was changed? I would have thought that more people would have prefered the video thumbnails setting left the previous way.
