Activity › Forums › VEGAS Pro › Vegas 9 Pro and full hd – rendering problems
  • Vegas 9 Pro and full hd – rendering problems
    Posted by Pavel Urbanek on January 10, 2010 at 11:35 am
    Hello,
    I’ve read a lot of posts on these forums that were related to my problem, but didnt find the solution, so i decided to make new thread about this specific problem.
    I have ca. 10mins long vid with lots of clips, transitions/fx in multiple tracks.
    Each track have some specific combination of CC (color curves, hsl adjust, saturation adjust, magic bullet looks)
    The project is set to 1280*720 and everything works fine, i can preview everything in video with all FX active and it just show what is supposed to and rendering is succesful also.
    Now the problem is that if i try to render it as 1920*1080 some/all FX sudenly turns off (even in preview!), same happens if i try to set the project settings to 1920*1080.
    Interesting is that this doesnt happen at resolution 1920*1050 or lower, but obviously those res are useless
    Roger Bansemer replied 16 years, 8 months ago 3 Members · 2 Replies
  • Marissa Martinez
    January 10, 2010 at 4:35 pm
    ok.
    I-Support-Niley. No Copyrighted anything.
    MaHRISah. Marissa
  • Roger Bansemer
    January 11, 2010 at 1:02 am
    Wish I had an answer. I render a project and 8 out of 10 times I have to start over as it just freezes up during the render and always at different points. Eventually it completes with enough tries.
    I’ve left messages with Sony but they NEVER reply. I’ve reinstalled, updated, you name it…
    You would think after paying $700 (or whatever it was) for a program, it would work better.
    I’m have Vegas9 32 bit installed and use Windows7 64bit. I had Vegas 64 bit installed and Vegas would crash every few minutes.
