Activity Forums VEGAS Pro Vegas 9 Pro 32 bit versus 64 bit stability
  • Vegas 9 Pro 32 bit versus 64 bit stability
    Posted by John Donner on April 14, 2010 at 10:29 pm
    I’m still using 8.0c 32 bit on my 64 bit OS, because the 64 bit version of 8 turned out to have stability issues.
    How is the current situation now with 9.0d 64 bit? How does it compare to the 32 bit version, is it just as stable?
    Thank you.
    John Donner replied 16 years, 4 months ago 3 Members · 4 Replies
  • Paul Goelz
    April 15, 2010 at 10:44 am
    With the exception of my text item crashes reported in another post, the 32 and 64 bit versions of 9.0 have been 100% stable for me on Vista Ultimate 64 bit. No issues whatsoever on SD or HD assets.
    Paul
  • John Donner
    April 15, 2010 at 3:53 pm
    Thank you Paul
  • Mark Prebonich
    April 25, 2010 at 2:47 am
    I had noticed some stability issues with Vegas Pro 9.0c with the 64-bit version. I was not having any difficulties with the 32-bit version. After I recently saw that 9.0d came out, I gave the 64-bit version a try agaion. I am glad to say that the previously seen artifacts seem to be resolved. I will keep using the 64-bit version of 9.0d for the time being.
    -Mark
  • John Donner
    April 25, 2010 at 10:02 am
    Mark, first you said that you had stability issues, later you talked about artifacts. Those are two different things. So what were the issues with 9.0c; unstable or artifacts and if there were artifacts, what kind of artifacts?
