Activity Forums VEGAS Pro Vegas 9 Nesting issue with audio
  • Vegas 9 Nesting issue with audio
    Posted by Jason Yip on September 15, 2009 at 3:21 am
    I created a new project, dropped an .m2t clip on the timeline, synchronized the audio track that I had recorded from another source and then saved the project. I would like to nest this .veg file in another larger project but when I drop the .veg file onto the new timeline the audio is all messed up. First of all it isn’t in sync and second, there is only about 2 minutes of audio and then nothing. Any ideas?
    J.
    Jason Yip replied 17 years ago 2 Members · 2 Replies
  • Graham Bernard
    September 15, 2009 at 8:54 am
    Known Bug. SONY is fixing it. Here’s the “workaround”:
    The work-around is: In the main (parent) instance of Vegas, create a time selection and start a render, but uncheck “Render loop region only”. You can cancel the render. Now when you edit the nested projects, the audio proxy will render fully.
    See if this helps/assists you?
    My workaround was to close and reopen the MAIN Project and save the Nests several times.
    Grazie
  • Jason Yip
    September 16, 2009 at 2:39 am
    It worked! Thanks!
