Vegas 9.0 render problem with gpu
HiVegas-users, after a long time i’m back again 😃.
Ihave a render problem.
Sincemore than 10 years i use(d) Vegas 9.0 Pro on my so called Edith-pc(Edith was my friend 🙂 ) based on Windows 7 Pro (Asus P8 H77-Vmotherboard, 16GB RAM).
Tillabout 4 years ago i used Vegas 9.0 to edit some experimentalvideoclips. Now, for an artificial videoshow i like to upgrade(adding several tracks) this ‘old’ clips (note: the Edith-pc stillruns not too bad).
BeforeI rendered my clips with RAM 16GB (CPU) but with the new added tracksit renders very, very slow (60 sec use 55 minutes). So i installedthe Nvidia GeForce GTX 970 (GPU), and the viewmonitor runs on it muchfaster than with the 16 RAM. So far so good.
Butthe problem is, how can i change (in Vegas?, in the Bios?) the renderoption from CPU RAM 16GB to the GPU GTX 970?
Thanksin advance, Herman.
