Activity Forums VEGAS Pro Vegas 8 Pro tiny audio glitch/click/noise when rendering out file
  • Vegas 8 Pro tiny audio glitch/click/noise when rendering out file
    Posted by Rikki Daman on August 22, 2009 at 12:12 pm
    Hey everyone,
    Got an annoying problem that I cant seem to pin down.
    When I render out an AVI file with MP3 audio via Vegas Pro 8 half the time I am getting a tiny click/glitch in the audio right at the beginning of the rendered file.
    I’ve tried using an audio fade at the beginning to see if that helped but it didnt; tried moving the timeline contents along half a second and that didnt help either.
    The source content is absolutely fine and its completely random, I can render out and get the click then render the same file and its fine the next time around – though rebooting the PC seems to help the most. Ive tried playing back the rendered files on 2 PC’s just to check its not my sound card audio system etc.
    I am currently trying to render out a hundred or so small video files and its driving me insane. Has anyone come across this type of issue before or know of any work around?
    Many thanks,
    Rik
    Shawn Bossick replied 17 years, 1 month ago 2 Members · 1 Reply
  • Shawn Bossick
    August 22, 2009 at 4:49 pm
    the audio cant start any early’ier than 500 ms a half a second, I think you said you did that, when you render down your project keep your audio at 48,000 16 bit and at least 512 kbs, I used to have a pop at the end of my project, it took me forever to figure that out, I had to make sure that the project contined 15 frames past the end point, than it disapeared, I still find that wierd
