Activity › Forums › VEGAS Pro › Vegas 8 pro external HD question
  • Vegas 8 pro external HD question
    Posted by Larry Brewer on August 19, 2008 at 10:01 am
    Intel Quad CPU
    4 gig RAM
    Win XP 32
    I am currently using a 1TB USB 2.0 external HD for media storage for a project I’m editing. Performance during actual editing is fine. Real time previews at 30 fps playback. Smooth transitions without jerky video issues.
    The problem occurs when I open any other window while Vegas 8 is running. MS word, PhotoShop, browser, even taskmanager. When I return to Vegas 8, It freezes while the USB 2.0 hard drive HD “reacquires” the data. This takes about 10 to 15 seconds and then everything returns to normal.
    Is my Hard Drive going to sleep? Anyone have a similar issue and a good work around?
    thanks
    larry brewer
    Larry Brewer replied 18 years, 1 month ago 3 Members · 5 Replies
  • Adam Rose esq.
    August 19, 2008 at 11:56 am
    OPTIONS / PREFERENCES / CLOSE MEDIA FILES WHEN NOT THE ACTIVE APPLICATION.
    turn that off.
  • Allen Zagel
    August 19, 2008 at 12:37 pm
    Also IMHO USB-2 is not the best for video work. My external HD’s on my editing computer are FireWire, and on the laptop eSATA both of which are much faster than USB.
    Does your external HD have a FW connection option? I’ve never encountered the problem you mentioned with FW – eSATA
    I use the USB connection on my internet computer for my externals but I don’t do any video work on that machine.
    Allen
    ASX Media Group, Inc.
    http://www.asxvideo.com
    NEW DVD – Europe, Trains-n-Trams
  • Larry Brewer
    August 19, 2008 at 3:12 pm
    That nailed it. Night and day difference. I wasn’t aware of the “Close media files when not the active application” option. Best advice ever. Can’t thank you enough.
    Larry Brewer
  • Larry Brewer
    August 19, 2008 at 3:17 pm
    Allen
    Thanks for the reply. My external drive doesn’t have firewire. But like I said, the media works quite well when I’m editing. The bit rate of the drive seems to be fine. It was the transition from one application to another that caused Vegas to freeze for 10 to 15 sec.
    Problem solved by “Close media files when not the active application” option in preferences.
    Still, I’ll look for firewire on future external drive purchases.
  • Larry Brewer
    August 19, 2008 at 8:20 pm
    Adam
    New issue regarding media. On occasion my media will be marked as offline. The clips listed in project media window will be grayed out. I can capture new media to the very same drive that Vegas 8 thinks is offline, and the new media can be placed on timeline and played. The new caps appear in the project media window not grayed out right alongside the grayed out clips.
    Thanks for your help with the previous issue. This issue is different in that there is no freezing of the Vegas program, just the “media offline” issue.
    larry Brewer
