Activity › Forums › VEGAS Pro › Vegas 8 “media offline” problem
  • Vegas 8 “media offline” problem
    Posted by Larry Brewer on August 20, 2008 at 11:14 pm
    Every time I capture new video into this project I’m working on, my previous clips from that drive go offline. I have to save my project, close Vegas 8, and reopen the project to bring everything back. Any ideas? USB 2.0 external hard drive. PC quad CPU, 4 gig RAM
    Larry Brewer replied 18 years, 1 month ago 3 Members · 6 Replies
  • Danny Hays
    August 21, 2008 at 12:22 am
    I just saw a post the other day on this. Look in your project properties and look for “Make media off line when not highlighted program” or something like that and uncheck it. Hope this helps. Danny Hays
  • Larry Brewer
    August 21, 2008 at 4:31 am
    Danny
    Yes, that post was advice for me and a somewhat related problem. ie Vegas 8 would lockup whenever I opened any other application on my PC. I unchecked the box and the problem was fixed. Now I can multitask my a** off and no lockups.
    Now I’m dealing with my video clips going offline whenever I decide to capture a new clip. Vegas doesn’t freeze or lockup, just all my clips in the project media window are grayed out and the clips on the timeline are marked “Offline”. Saving, closing and re -starting vegas brings it all back and I can go on. I’m hoping there is another box somewhere that I can uncheck and fix this issue! Thanks for the reply.
  • Steve Rhoden
    August 21, 2008 at 7:52 am
    larry,
    If the problem got solved by this https://www.youtube.com/watch?v=QSiyvfXVtpk&feature=user
    Read the posts that follows this video.
    Also just simply do your captures without having vegas open..as a
    matter of fact, nothing should be open or running when you are
    capturing.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    http://www.youtube.com/hentys
  • Larry Brewer
    August 21, 2008 at 8:52 am
    Steve R
    Thanks for the suggestion. I had already unchecked the “close media files when not the active application” box on preferences and it did help with a lockup problem I was having earlier today. (opening any other application would freeze Vegas)
    But the media offline after each capture problem persisted. The files were going offline the instant I hit the “done” button on the Capture Complete window after batch capture. So… I unchecked the “Add captured clips to Project Media List” box in the Capture Complete window and all is well. I now import the clips into the Project Media List window manually.
    I would rather not open and close Vegas 8 everytime I capture clips. Some of my projects are very large, closing and re-opening can take a while.
    This problem is certainly a bug that needs to be fixed. A nice feature of Vegas Capture 6.0 was to have the clips fall into the proper media bin in the Project Media List after each capture. This feature has worked quite well in the past. I’ve used it successfully many times. Did the problem begin with Vegas 8? Is it my USB drive?
  • Steve Rhoden
    August 21, 2008 at 9:33 am
    Yes, USB drives has many short-comings…..A firewire drive is what i would highly recommend.
    Steve Rhoden
    Creative Director
  • Larry Brewer
    August 21, 2008 at 4:48 pm
    I would not disagree with your conclusion. And if speed were the only factor, Firewire external drives would always be the best choice. As I take inventory around my studio I have counted 15 external drives acquired over the last 4 years or so. 2 are firewire only, 2 are combos and the rest are USB 2 drives.
    The recent issues I’ve had with external drives, “Media Offline” and Vegas locking up, involved USB drives for sure. But… in both cases the drive continued to performe just fine as far as my PC was concerned. The data, media, was always there. I could access it and play it with WM player. It was Vegas that was confused.
    And when Vegas 8 wasn’t confused, the USB drives performed just fine. DVCam media and HDV media played in realtime, full frame, with “good” setting on my preview window. I can access media from the USB drive and render back to the same drive with predictable results and good speed.
    The only real and fatal problems I’ve ever encountered with external hard drives were with the firewire drives. Admittedly they are much older and early generation drives. I recall several occasions where I needed to reconnect or cycle power to the FireWire drives for the PC to bring them online.
    I appreciate everyones help. I have simple work arounds that will get me through my current projects. I’ll try the firewire port on my combo drives to get an apples to apples comparison in the near future.
