vegas 8 1440 hdv
Posted by Howard Steiger on July 24, 2009 at 1:03 amif i am editing in 1440 x 1080 and i render in it will it look prper on an hdtv 1920
John Rofrano replied 17 years, 1 month ago 2 Members · 3 Replies -
John Rofrano
July 24, 2009 at 2:08 amYes, as long as the PAR is 1.333. 1440×1080 PAR 1.333 = 1920×1080 PAR 1.000.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Howard Steiger
July 24, 2009 at 6:34 amThank you. May I ask how i make sure of this par in vegas 8?
Thank You
John Rofrano
July 24, 2009 at 10:56 amOpen your project properties with Alt+Enter and check the Pixel Aspect Ratio there. If you used one of the standard project templates for 1440×1080 it will be set correctly for you. Then when you render do the same. Use a standard HDV 1440×1080 template and the PAR will be set correctly.
~jr
