vegas 7 going to upgrade
Posted by Michael O’connor on November 13, 2006 at 5:46 pmI have the vegas 7 upgrade, I’m going from v 4 to 7. is there anything I should know before I start? Or is the upgrade simply putting the software in and following instructions. Thanks.
Michael O’connor replied 19 years, 10 months ago 4 Members · 6 Replies -
Edward Troxel
November 13, 2006 at 5:54 pmJust follow the instructions. After installing, you will have TWO versions of Vegas installed – 4 and 7 – AND you will be able to USE either one of them. The upgrade won’t “replace”, it will install beside it.
Make sure you install the latest update from the Sony site which may be newer than what is on a CD.
Jerry Waters
November 15, 2006 at 12:24 amHowever, once you use 7 on a veg, it is 7 because it isn’t backward compatible.
JerryW
Bob Y
November 15, 2006 at 3:31 amEdward
Does that go for Architect 4 too. I also upgraded from Vegas 4 to Vegas 7 and DVD Architect 1 to DVD Architect 4. Does it install beside and not over, and can i still use DVD Architect 1 and DVD Architect 4 separately.Thank you
BOB
PS
Edward I Really appricate all the help you have given me and others again I thank you. -
Edward Troxel
November 15, 2006 at 4:10 pm
