Activity Forums VEGAS Pro Vegas 7 and Canon Powershot (A530) AVI clips
  • Vegas 7 and Canon Powershot (A530) AVI clips
    Posted by David R israel on May 22, 2007 at 2:14 pm
    Hi —
    a friend returned from an excursion with her USB mass
    storage drive carrying video clips taken by a companion’s
    Canon A530 Powershot camera. Inspection reveals the
    clips (AVI files) to be 640 x 480 in size, and they
    evidently run at 10 frames per second.
    I can view and hear them via Windows Media Player.
    But I can’t figure out how to edit them.
    My problem is — when I pull these clips into Vegas 7,
    all that shows up on my timeline is the audio track.
    The video won’t come in at all. I’ve tried a few options
    in the Project settings — there seems (in Vegas 7) to be
    no 10 frames/second DV option. But really that should not
    in itself be cause enough to exclude a video clip from the
    program, should it? (I am able to custom-adjust the project
    setting so that 640×480 is the standard frame size — but
    this does not suffice to affect or solve the Where-Are-My-
    Video-Tracks? situation.)
    Has anybody successfully worked with such clips in Vegas?
    If so, — how?
    thanks!
    David
    david raphael israel
    (in bhopal, india)
    Mike Kujbida replied 19 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    May 22, 2007 at 2:28 pm
    Do a search here for “MJPEG”. Bottom line is that you need to install the codec used by that camera. Many still cameras use the MJPEG codec. Some use other codecs.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    May 22, 2007 at 2:31 pm
    Odds are that you need an MJPEG codec.
    Google it and you’ll find several links.
    Most of them are in the $20 price range.
  • David R israel
    May 23, 2007 at 6:58 am
    Edward and Mike,
    many thanks — installing an MJPEG codec sufficed to
    solve the problem.
    There’s now one fine-point questions I wonder about.
    A curiousity of this MJPEG footage is that, even though
    it is only 10 frames per second, when I insert it into a
    Vegas timeline — where the Vegas project is set at a PAL
    standard framerate (25 frames per second) [I’m in India,
    and working in PAL here], oddly enogh, every frame — i.e.,
    all 25 frames per second — appears as a UNIQUE image on
    the preview screen, even thogh there are only 10 frames
    per second visible on the timeline.
    Can somebody explain this? Is it a characteristic of the
    MJPEG format — or of the Vegas timeline — to extrapolate
    an image in this way? It seems quite surprising to me —
    and makes me wonder whether, if I instead set the project
    at 50 frames per second (I think there’s that option, so-
    called “double PAL”), I would then have 50 unique images
    per second from this 10-images-per-second footage? The
    phenomenon strikes me as almost a case of science fiction.
    Awaiting enlightenment,
    d.i.
    (in bhopal, india)
  • Doug Graham
    May 23, 2007 at 2:51 pm
    When I had the same problem, I found that I could import the video into MovieMaker, then export it in a format that Vegas could read.
    Regards,
    Doug Graham
  • Gary Kleiner
    May 23, 2007 at 3:03 pm
    The picons that make up the filmstrip representation on the timeline are for a loose reference and change depending on how much you are zoomed in or out. They are not necessesarily a direct reference to each of the frames that the video is comprised of.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • David R israel
    May 23, 2007 at 4:32 pm
    Gary,
    although you make a generally useful point,
    it’s beside the point in this case. What I’m
    telling you is that with this footage, I get
    25 distinct, different frames per second! —
    despite the fact the footage is clearly
    marked (in metadata) as being “10 frames
    per second).
    And incidentally, those 10 frames do happen
    to be accurately reflected (far as I can tell)
    by the 10 images per second that I see on the
    Vegas timeline, when looking at the farthest
    level of granularity of view.
    Now — can you explain the phenomenon?
    Also note this: Many of the images are rather
    blurry. This was video of martial arts, and
    there’s a lot of motion — but I still am
    inclined to believe that 15 our of every 25
    of these distinct frames have been created in
    Vegas (and/or by the MJPEG codec) as extrapolated
    approximations of intermediate stages of what the
    software opines to have been there.
    Agree? Disagree? Other explanation?
    cheers,
    d.i.
    (in bhopal, india)
  • David R israel
    May 23, 2007 at 11:06 pm
    ps — and just to clarify:
    as initially said, these “25 frames”
    that I mention are in view on the
    Preview monitor, when moving, frame
    by frame, along the timeline (when
    the project is set to 25 frames
    per second and the timeline ruler
    is set to “Time and Frames”).
    There are NO two identical frames
    among those 25 / sec frames– each
    is unique.
    The audio is at a normal rate, and
    has the same duration as the video.
    Thus, it seems quite clear that 15
    new video frames have been created
    here. As I was unaware of this as
    a thing that might happen, I thought
    I’d ask about it — and am curious
    whether it can be attributed to
    Vegas per se, to the MJPEG Codec
    per se, or (as I might guess) to
    a combination of the two?
    (in bhopal, india)
  • Mike Kujbida
    May 24, 2007 at 3:12 am
    David, my guess is that it’s Vegas that’s doing some kind of interpolation.
    I just loaded in an avi file shot with my Canon digital still camera (320 x 240 @ 15 fps).
    I applied the timecode FX and then stepped through it on the Vegas timeline.
    What’s interesting is that, while the Vegas time display shows it incrementing frame by frame, the timecode FX only displays the odd frame numbers. That is, it shows 00:00:00:00, 00:00:00:01, 00:00:00:03, etc. with each odd frame number being displayed twice.
