Activity Forums VEGAS Pro Vegas 7 and Blackmagic decklink Extreme PROBLEMS
  • Vegas 7 and Blackmagic decklink Extreme PROBLEMS
    Posted by Eimantas on October 23, 2006 at 7:20 am
    I’m using Blackmagic decklink Extreme and Vegas 6 for work with Beta SP recorder.
    I have problem with analog input in Vegas 7.
    Print to tape works correctly (print to Beta SP).
    I recieved this explanation from Blackmagic:
    Unfortunately, Sony has not verified the use of analog vidoe connections for capture and and we know that it will not work.
    Unfortunately, there’s nothing much we can do as Sony uses a closed architecture for Vegas which means that we cannot write any additional support or respond to any bug reports.
    We’ve submitted reports about issues we’ve come across with Sony and hopefully, they can do something about it.
    Regards
    Kristian Lam
    Blackmagic Design
    ” target=”_blank”>https://www.blackmagic-design.com
    Can I have any comments or suggestions from Sony side?
    Thanks in advance for reply
    Teddybe replied 19 years, 11 months ago 3 Members · 2 Replies
  • Sada
    October 23, 2006 at 6:19 pm
    You would be better off addressing this to Sony Media in Wisconsin. They also have a site.
  • Teddybe
    October 27, 2006 at 5:53 pm
    Tested Vega’s with Decklink Extreme HD.
    By changing the preview setting to Decklink, it says it can’t find the hardware card…
    Decklink in 1920×1080 mode with latest drivers 5.7.2
    Should I realy install the 4.8.1 drivers (Vegas6 certified driver)? I also have teh CG-100 v1.51 soft from Datavideo witch needs driver 5.5.1 or higher…
    Anyone a solution?
    ThanX
