Activity Forums VEGAS Pro Vegas 6.0 importing audio incorectly
  • Vegas 6.0 importing audio incorectly
    Posted by Cdmanproductions on April 6, 2006 at 2:32 am
    when im importing a video/audio file, in imports the videos fine but when it comes to the audio it out of sync, and vegas doesnt seem to preview it very well, really choppy. i can play the file video/audio flawlessly in windows media player, power dvd, pretty much and other media player. its just when i try to import it into vegas is when i have problems.
    here is my method of capture.
    i transfer files directly from my dvr thru firewire to my computer. the end file format is .mpg, there is no way for me to capture it using a capture other than the program CapDVHS (that i have found atleast) and there really isnt any settings in that program.
    thanks in advance
    Cdmanproductions replied 20 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Anotheruser
    April 6, 2006 at 5:37 am
    What kind of soundcard do you have?
  • Peter Wright
    April 6, 2006 at 7:05 am
    MPG is not really designed for editing – it can be done, but preview playback with such a compresed format can be un-smooth as you’re experiencing (The other apps you mentioned are optimised for playback rather than editing).
    To test that the final result will be better, drag to select a short loop region in the timeline and press Shift B for a Ram Preview – this should be smooth and in synch.
  • Cdmanproductions
    April 6, 2006 at 9:54 am
    i have an audigy 2 platinum sound card, but i dont capture audio with it, the video/audio is all captured through the firewire cable.
  • Cdmanproductions
    April 6, 2006 at 9:57 am
    ya i know its not the best format, but i think thats what the format is on my dvr so thats what i end up with after the capture. ill try what you said to do, thanks.
  • Mike Kujbida
    April 6, 2006 at 3:53 pm
    Do you have a DVD drive on your computer?
    If so, Vegas 6.0c added DVD import capability.
    File – Import – DVD Camcorder disc.
    6.0d added scene detection capability.
  • Rob Mack
    April 7, 2006 at 4:40 am
    This is assuming his dvr can make DVDs.
  • Cdmanproductions
    April 7, 2006 at 7:06 am
    no my dvr cant make dvds, but what i have found out is that i can just encode the file into a .vob, with ffmpeg, then vegas doesnt have a problem. that prgram does a pretty good job, but now im wondering if there is a better program out there to convert it? thanks
