Activity Forums VEGAS Pro Vegas 6.0 Crop problem
  • Vegas 6.0 Crop problem
    Posted by Jeipei on November 8, 2005 at 11:20 pm
    When I crop on a piece of footage, zooming on the scene, the result is not sharp, but there are a lot of lines all around the various items in the footage. In other words, the contour of the person, for example, is something like a saw.
    I don’t know if the explanation is clear. I have 2 pics od the problem, but i don’t know where to post them as i don’t have a web space.
    Thanks everybody for the help.
    Gilles Pialat replied 20 years, 10 months ago 3 Members · 3 Replies
  • Gary Kleiner
    November 9, 2005 at 12:13 am
    Are you using TRack Motion or Pan/Crop? The latter will give you better results.
    Also, what is the resolution of the image? If it’s not high res, you just can’t zoom in too far and expect good results.
    Gary
  • Jeipei
    November 9, 2005 at 1:15 am
    I’m using crop on a footage not on an image.
    On a pic there is no problem, you can crop with very good quality.
    On a video PAL 720X576 there is this problem.
  • Gilles Pialat
    November 9, 2005 at 7:03 am
    Check in your project properties > Deinterlace Method > Blend Fields.
