Vegas 6.0 audio sync problems
Posted by Craig Wallen on October 12, 2006 at 7:14 pmIn preview ir is working perfectly (native Panasonic DV codec) but,when I render it in the DV NTSC template the audio is out of sync with the video. Should I be using the Panasonic DV codec instead? If it is not that what else could cause that to happen?
Mike Kujbida replied 19 years, 11 months ago 2 Members · 5 Replies -
Mike Kujbida
October 12, 2006 at 9:44 pmNative Panasonic DV codec??
Assuming you captured via firewire, no codec is involved (until render time, that is) as it’s a digital transfer from camcorder to computer.
Or is this footage from something else? -
Craig Wallen
October 12, 2006 at 9:55 pmIt is captured from a multiples of DV cams using the Panasonic Capture Codec as i understand is slightly compressed compared to uncompressed AVI
which are even more huge than panasonic DV codec. but, anyways that was the source was and yes via firewire. -
Mike Kujbida
October 13, 2006 at 12:17 amI’m confused here 🙁
By it’s very nature, DV is already compressed at 5:1 so why a different codec was used is beyond me.
Was this footage captured using Vegas? I’m guessing no but I’ll ask anyway. If no, how was it captured (i.e. what NLE)? -
Craig Wallen
October 13, 2006 at 1:04 amI captured with a program called WInDV and when i play the captured files with a media player all is fine there.( and I never had a problem with that before in many many captures) and then i put into the Vegas software I edit and all that and everything seems to be perfect there as well. Then when I got to render in NTSC DV template is where the audio sync problem arises. In other software I never had this problem but, this is bugging me about the Vegas software and trying to figure out what I am doing wrong. because the vegas software has some neat features.
Mike Kujbida
October 13, 2006 at 10:26 amNot sure what to suggest as I haven’t used WinDV. I find that VidCap, the Vegas capture app, has always worked for me.
I looked at the WinDV site. Is it possible that you’re choosing type-1 AVI files instead of type-2? Or is it the other way around? Hopefully someone else can answer this question.
