Activity Forums VEGAS Pro Vegas 6 with Decklink HD Pro
  • Vegas 6 with Decklink HD Pro
    Posted by Stewart Mayer on April 24, 2005 at 11:38 pm
    Hello,
    I’ve got a Decklink HD Pro system I built, running Premiere Pro 1.5, and I’m thinking of trying Vegas 6 now that it “supports hd”. Has anyone seen this working??? My goal is to work with uncompressed HD and HDV footage on the same timeline with realtime playback through the Decklink HD Pro’s analog HD output, decklink hd with premiere can only playback uncompressed HD in real time (currently). Ideally, I’d bring in the HDV footage via firewire and the HDcam footage via HD-SDI uncompressed, and anytime anything needs rendering it would render out uncompressed so not to loose quality.
    Any knowledge or experience you guys have got with this work flow would be greatly appreciated.
    Stewart
    Donatello replied 21 years, 5 months ago 2 Members · 1 Reply
  • Donatello
    April 25, 2005 at 3:42 am
    just make sure your hard drives have the thru-put for the uncompressed HD ( ?? 122mgs ?) = you’ll need a RAID … the HDV will be no problem ( either as mpeg or cineform files)
