Activity › Forums › VEGAS Pro › Vegas 6 renders out of sync
  • Vegas 6 renders out of sync
    Posted by John Quick on January 25, 2007 at 1:54 am
    When I render a long program to a new .avi file, the rendered file is out of sync by around 10-13 frames. (It varies.) How can I prevent this from happening?
    Michael Morone replied 19 years, 8 months ago 7 Members · 11 Replies
  • 11 Replies
  • Gary Kleiner
    January 25, 2007 at 4:35 am
    [John Quick] “the rendered file is out of sync”
    Out of sync with what?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • John Quick
    January 25, 2007 at 5:15 am
    The sound is out of sync with the picture in the rendered file
  • Brett Jones
    January 25, 2007 at 10:53 pm
    I recently had the same problem when converting some captured MPEG2 files to Sony MP4 (for use with a PSP). My immediate thought was that my computer wasn’t up to the task, but that doesn’t strike me as the answer since the audio went out of sync during a conversion, not a capture.
    Anyone have any ideas?
  • John Quick
    January 25, 2007 at 11:04 pm
    I talked to Gary Kleiner on the phone this morning, and he has the same idea that you do, Brett: he thinks it’s most likely a hardware problem.
  • Terje A. bergesen
    January 26, 2007 at 4:19 am
    If the audio is in synch before you render, it is highly unlikely that it is a hardware problem that makes it out of synch since the “only” hardware involved in rendering is the CPU.
    You say you render to avi, which isn’t really saying much since avi can be just about anything. What codec are you using for video, what codec are you using for sound?
    Terje A. Bergesen
  • John Quick
    January 26, 2007 at 5:00 am
    Terje, I’m using the “Render as…” choice in the File menu in Vegas, and then choosing .avi as the type of file to render the program.
  • Allen Zagel
    January 26, 2007 at 10:55 am
    Okay, but what template are you using? Default? Maybe that’s your problem. Try doing the same thing but go to the template box below the AVI and choose NTSC-DV (or PAL is you’re using PAL), or any of the other templates besides the default uncompressed.
    Allen
    ASX Media Productions
    https://www.asxvideo.com
  • Terje A. bergesen
    January 26, 2007 at 6:45 pm
    Just some background info. There is no such thing as AVI video. AVI is a wrapper format, not a video or audio format. AVI can contain data encoded with many types of codecs. When you encode to AVI you also chose the codec to use. For video editing you should typically use DV-AVI matching your source, for publication you may use DiVX or similar.
    Terje A. Bergesen
  • Jerry Waters
    January 27, 2007 at 10:58 pm
    Is it out of sync for the entire clip or does it get progressively worse, that is, starts in sync but gets out by the end?
    JerryW
  • John Quick
    January 27, 2007 at 11:18 pm
    I’ve had it go both ways. One project started out in sync, then got worse to about 10 frames out. Another was consistently about 13 frames out.
