Activity Forums VEGAS Pro Vegas 6 render times
  • Vegas 6 render times
    Posted by Videot on April 24, 2005 at 11:35 pm
    I just tested V6 versus V4 render times and got some interesting results.
    On an AMD 2.2GHz dual proc machine using the standard rendertest.veg file.
    V4 rendered in 3:20; V6 rendered in
    2:20! That is about 30% faster which is great news.
    Later on a single 2.8GHz pentium 4 with HT; V4 got a time of 1:32 but V6 clocked in at 2:05!!!!
    Not what I expected after the earlier improvement.
    Any ideas or common experiences?
    I thought that V6 was supposed to take advantage of HT technology and use it just like a dual proc but these tests indicate that is not the case.
    Storm Crow replied 21 years, 4 months ago 4 Members · 5 Replies
  • Peter Wright
    April 25, 2005 at 1:04 am
    So far, it seemd V6 uses dual processors much better than HT. Sony have said that they hope to improve this somewhat, but it seems the benefits of HT will remain less than dual processors.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Storm Crow
    April 26, 2005 at 1:21 pm
    Try adjusting the thread in Vegas 6 to 1 instead of 4. I did this on my overclocked P4 3.0GHz (OC’ed to a 3.6GHz) and got a slight improvement over Vegas 5 render times but I had to adjust the threads that Vegas 6 sees down to 1 thread.
    Good friend, around these hearth stones, speak no evil of any creature
  • Dr. Dropout
    April 26, 2005 at 2:31 pm
    Storm Crow…have you always been running an overclocked system?
  • Storm Crow
    April 27, 2005 at 12:18 pm
    Once I built this machine and figured out how to OC it and have it be stable, yes. It never crashes or anything and it is air cooled by 6 case fans and 1 Zalman. When I was having the problem you helped me with, it did not matter if I had it OC’ed or not, I still had the problem.
  • Storm Crow
    April 27, 2005 at 12:28 pm
    All renders were done in MPEG2 at best and with the video slider quality set to best. The default 6,000,000 max and 4,000,000 average.
    VEGAS 5 vs. VEGAS 6
    P4 2.4gHz with 1 gig or SDRam
    Vegas 5 – 02:03
    Vegas 6 – 02:05
    P4 3.0gHz OC’ed to a 3.6gHz with 1 gig XMS SDRam / 4 Threads Selected
    Vegas 5 – 01:20 ? See below
    Vegas 6 – 01:49
    P4 3.0gHz OC’ed to a 3.6gHz with 1 gig XMS SDRam / 1 Thread Selected
    Vegas 6 – 01:15
    P4 3.0gHz with 1 gig XMS SDRam / 4 Threads Selected
    Vegas 5 – 01:32 using 50 – 58% processor
    Vegas 6 – 01:42 using 100% processor
