Activity Forums VEGAS Pro Vegas 6 question
  • Vegas 6 question
    Posted by Brian Luce on October 19, 2007 at 12:20 am
    I filmed a video with a 16×9 CCD camera. Edited in Vegas 6 and rendered in main concept mp2. Resulting DVD playing on a 4:3 TV wasn’t letterboxed and had that distorted scrunched up look.
    What setting should I use to make it play properly on a 4:3 TV.
    Brian Luce replied 18 years, 11 months ago 3 Members · 4 Replies
  • Douglas Spotted eagle
    October 19, 2007 at 12:40 am
    You didn’t render to the NTSC widescreen template?
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Brian Luce
    October 19, 2007 at 1:11 am
    “You didn’t render to the NTSC widescreen template?”
    I just used the default template.
  • Don Bloom
    October 19, 2007 at 1:13 am
    right and that caused the problem. In the template menu there is a NTSC widescreen template and that’s the one you need to use to take care of the problem. You’ve got to use the correct template or else you get bad looking results.
    Don
  • Brian Luce
    October 19, 2007 at 9:54 am
    Suppose you’re mixing 16:9 and 4:3 on the same timeline. You want it to play on 4:3 and 16:9 sets without distortion. Still use NTSC wide screen?
