Activity › Forums › VEGAS Pro › Vegas 6 DVD made and video is extremely blurry
  • Vegas 6 DVD made and video is extremely blurry
    Posted by Dpuma8 on September 7, 2005 at 11:01 pm
    Hello everyone. I have been making a movie for the past year and a half and it is finally finished. I did the editing in Vegas 6 but when I make a DVD (using either DVD architect or Pinnacle Studio) there are a lot of parts where the video is blurry. It looks like there is a kind of ghost trail effect happening on movement shots while others are just fine. In Vegas, I made the video in both .AVI and .MPEG2 formats.
    Is there any help I can get? I\t is scaring me that all these problems might have screwed everything up
    Edward Troxel replied 21 years ago 3 Members · 4 Replies
  • Stephen Mann
    September 8, 2005 at 12:45 am
    You aren’t clear if the problem is in the AVI file and the MPG file, but it sounds like your bit rate is too high.
  • Edward Troxel
    September 8, 2005 at 2:09 am
    Which MPEG2 preset did you use?
    Edward Troxel
    JETDV Scripts
  • Dpuma8
    September 9, 2005 at 12:18 am
    I did not use a template. I usually try to make an .AVI file because .MPEG2 has bad quality. If you are asking about the template, I use the NTSC DV template but then I change the quality to best. What about the bitrate?
  • Edward Troxel
    September 9, 2005 at 1:26 am
    The “default” template is bad. It’s always recommended you start with one of the DVD Architect presets. You can also look at Vol 1 #7 of my newsletters for more info.
    Edward Troxel
    JETDV Scripts
