Activity Forums VEGAS Pro Vegas 6 does not recognize camera for capture, yet Nero & Win Moviemaker work
  • Vegas 6 does not recognize camera for capture, yet Nero & Win Moviemaker work
    Posted by Virginia Morley on January 5, 2007 at 2:10 pm
    Hello!
    I am baffled. Nero & Moviemaker will capture my DV video from the camera no problems. Vegas 6 will not even recognize my camera. I need Vegas to split the scenes to save as individual files.
    I went File-Capture video (camera was connected with firewire/set ready to capture etc)& initially didn’t even get the capture dialog box. So then I hit Options-Preferences-Video (tab)& unchecked the “use external video application” box. This then resulted in the dialog box opening.
    HOWEVER: the capture dialog box gave me a big blue box with “device not available” In the ‘device’ tab I got 3 choices to choose from (none of which worked): “none”, “IEEE1394/MPEG TS device” & “BlackMagic Design Decklink”. I would have expected my Panasonic camera to be listed here.
    Any suggestions as to what is going on here? I don’t know where else to go to adjust settings.
    Do I need some kind of driver for my IEEE connection? Do I need some kind of special codec?
    I would appreciate any suggestions! Thanks very much!
    Virginia Morley replied 19 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Alex Bennett
    January 5, 2007 at 8:16 pm
    I just hope that you put your firewire plug into the PC the right way round. Despite its shape it does go in both ways. I did this and as a result I blew the i-link on my camcorder which is now in for repair! Hope this is not your problem.
  • Edward Troxel
    January 5, 2007 at 10:02 pm
    Sounds like you’re using the INTERNAL capture app and should be using the EXTERNAL capture app.
    Internal = HDV
    External = DV
    When you choose capture, it should ask internal or external. If it does not, you selected that option as your default and will need to go into Options – Preferences and change it.
    Edward Troxel
    JETDV Scripts
  • Virginia Morley
    January 6, 2007 at 5:00 pm
    Thanks for this info! Could you please clarify: do you mean Options-Preferences-Video from the main toolbar? If I check the “Use external video capture application”, C:\Program Files\Sony\Vegas 6.0\vidcap60.exe is highlighted in the box below. Problem is: when I then go File-Capture video………….nothing happens at all. No Capture dialog box opens, nothing.
    If I uncheck this box, the Capture dialog box opens, but then I get the big blue “Device not available” box where I assume it would otherwise say Panasonic DV camera (my camera).
    I went & found the Video Capture Release notes in the Vegas program files, & they advise to check the “Enable DV device control” in the Preferences dialog. AGAIN: WHERE IS THIS??? This does not appear ANYWHERE in Options-Preferences in the main program, & also not in the preferences contained in the Capture dialog box.
    Where else can I find some Preferences to change? I assume the INTERNAL/EXTERNAL capture advice you have given is somewhere different to these 2 locations I have described. I am using Vegas 6 build 84.
    Many thanks for your advice!
  • Edward Troxel
    January 7, 2007 at 3:05 am
    The “Use External” option SHOULD be checked. When choosing File – Capture, a separate program should open up to do the capturing. The other box you mention tells what program will be opened.
    What version of Vegas 6 are you using? I recall some older versions where the VidCap program did not load correctly. Update to Vegas 6.0d (the most current version) and then see if all works fine.
    Edward Troxel
    JETDV Scripts
  • Virginia Morley
    January 7, 2007 at 6:40 am
    I think you have the answer! I also found some stuff on another forum about Vidcap 60.exe not opening on the early build 84 of Vegas. This may also explain why I don’t have some of the options in Preferences (e.g. “Enable DV device control”), which should be where you all say it is. Maybe that option was added after my build of the program.
    So can I just download this 3.5MB Vidcap 60.exe (d) from somewhere, or do I have to download the whole 250MB Vegas program to use it? I’m not in a position to buy another Vegas program & am not on broadband/cable to be able to download hundreds of megabites.
    Thanks so much for your help!
    Virginia
  • Edward Troxel
    January 7, 2007 at 9:49 pm
    You need to download the 130 Meg Vegas 6.0d update. I understand not having broadband. I’m able to download the updates on the DSL at work. If you don’t have that option, do you have any friends with DSL? If yes, download it there, burn it to a CD, and then install it on your home machine.
    Edward Troxel
    JETDV Scripts
  • Virginia Morley
    January 7, 2007 at 11:50 pm
    Thanks very much for your help! I will go find some friends………….
