Activity Forums VEGAS Pro Vegas 18 Crashing — Autosave Frequency
  • Vegas 18 Crashing — Autosave Frequency
    Posted by Sean Michael on March 14, 2021 at 3:34 pm
    Vegas 18 crashes frequently. In fact, it crashes so frequently that the 5-minute autosave frequency is not sufficient. I would like to increase the autosave frequency to save a backup file every minute. Unfortunately the previous method to change autosave (Options >> Shift+Preferences) does not seem to work in Vegas 18. Can anyone advise the best way to make this change? Thanks!
    Red-rob Rothkopf replied 5 years, 5 months ago 2 Members · 2 Replies
  • Red-rob Rothkopf
    March 14, 2021 at 3:55 pm
    Use the advanced autosave features they added in 17. It may be called advanced backup.. under the tools menu I believe. You can set frequency and location for minor, major and critical backups, essentially defining a frequency and retention policy.
  • Red-rob Rothkopf
    March 14, 2021 at 3:59 pm
    On frequent crashes.. that sucks. As is usually the case, not everyone is having that same unstable experience that you’re having.
    Is the crashing project-specific? Reproducable via a series of steps?
    perhaps a particular favorite transition or plugin is causing issues?
    have you tried the various steps like disabling GPU, dynamic ram preview of changing the file handler if there is a particular file type (or file) causing the grief?
