Activity Forums VEGAS Pro Vegas 15 w/ QT Files
  • Stan Willis
    May 10, 2019 at 4:02 pm
    Hi George,
    Thanks for your quick reply
    Here it is:
    General
    Complete name : I:\Henry Lowther\2019-04-18_210320.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/avc1)
    File size : 9.05 GiB
    Duration : 13 min 31 s
    Overall bit rate mode : Variable
    Overall bit rate : 95.9 Mb/s
    Encoded date : UTC 2019-04-18 21:03:21
    Tagged date : UTC 2019-04-18 21:03:21
    PANA : ­Ú / *¡‚®ªŠú«ª¬îÊî®|¾®æÊ)͵øª/*ª¢®®º®Ì¨ŒÈêîʨJî¹Néøêª²üܪÚìjˆî¨¨êíÚª®Œ®ˆ ¯èøûî¬êú¬Ø®êꢎˆ̪êÄʺl©,ª® êšäêíܨš¶¼ÝhëìªÊª¡/J꺚îêꪋÅÿì쪞íé / ªÌìê£ØzìäÈᮊš¬¾–ê¿®,®Ì˜«ŠÈê / Ìê¨úêꮩèꫨÙl¼ïÌȪ è ëμ§Îþû®«®®J®«Z†©¬ˆŒˆj»Ì®êªî늊®ªŠ¸®¬J¬..ʂæÉ®ªª˜ª½šþª¬¼¨îú«êl¾ëŠ­ªþª¨î›äª«Îîè.fêªÛ®ú©ŽJ®Î¯Šèî fúªªªÈËìʺê¨îªÍˆ¨êèú§nª›È¸ÎêˆnªŠˆ:ª«ú®ˆËþ&¨îž¬ªøê¨ˆª¿î†îÈî­èî®êÎïŠB®ç / Ú®®ª¨Ê‰©ªª¢ª®†®É»Š«Ê¡*ª·í»ºÞêêˆÎª’سªü«¾¬Š¨»Š¸¢Jîîèìèª‹ªªî¬êýŽþ­‚h›jˆ« ªhk«èˆ¨lìʊ膪ȮÚꪫ¬Ú§æª™­É‹ª®Š¾®¢¨Šª¸èn®žÈêÞî¿î©#¨º«:‰ïÌ<Ьª†îî®*;f*ª~¨ªÓúàÎ鯨ºÎüΪ(ý¸Î¾ÊLªªŠž®èëì­Î꘼¬ºŒOЬJ¬ªÊꮌÜ슪¨®þÞÞ.›Èîîïê¨H™ÑʨØîþhªkèªêꊩ¨¢Š®¢ÚŠª®êêˬˊÊ讫«ŠªšâŒ®Êî«©ê:Ê­¨ºîèhÈ»ˆÏŽàˬî‚ÂêÊ*®»þªj¨ª¯¯8ªºˆÌ«èŪ®ª®ª*ëžêîîÈ
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.1
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Variable
    Bit rate : 94.3 Mb/s
    Maximum bit rate : 106 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.455
    Stream size : 8.91 GiB (98%)
    Color range : Full
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    Audio
    Format : PCM
    Format settings : Big / Signed
    Codec ID : twos
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 149 MiB (2%)
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 00:25:24:04
    Time code, striped : Yes
    Bit rate mode : CBR
  • George Dean
    May 10, 2019 at 4:42 pm
    Stan, can you post your settings in the GH5, so I can duplicate them in my GH4. My GH4 source is almost identical to yours, but want to match the camera settings as close as possible. Also what is the length of the source that crashes when you use Pan & Crop? If it is the file you used for the Mediainfo above, I have that 13 minutes 31s. I want to try and duplicate your crash.
    Best Regards……George
  • Tyson Onaga
    May 10, 2019 at 6:36 pm
    > 1- You are running QT 7.7.9. You should be running 7.6.8 Nothing above that version.
    Why is this (not that I doubt you) … ? I’ve been using 7.7.x for years with no issues except in Vegas 15 where the Track and Preview window must be ‘non-repaintable’ while the script executes. Also, I can’t find any COW threads re: 7.6.8 where this is the version to use.
    2- .MOV is a container. Just like a box, it can have something different inside.
    I know …. most of the mov files are from Rampant Design or Digital Juice. They are ProRes, Animation, PhotoJPG or PNG. Without QT installed, Vegas won’t open them.
    Thanks again,
    – tyson
  • Stan Willis
    May 10, 2019 at 6:44 pm
    Hi George,
    I shot the clip about a month ago. It would have been fully manual, stabilization on (including the lock feature that the gh5 has) . photo style natural , rec format was probably mp4(LPCM), Quality 4K 8bit 100Mn 25fps.
    The clip itself is about 9.5Gb so it’s a bit large to send – I would in any case need permission from the artist to do that.
    I seem to be able to edit clips in DaVinci Resolve 16 beta 2 free version without problems though they don’t play in real time (I could create proxys ) and the rendering quality isn’t the best. I would be grateful for any thoughts you may have.
    Many thanks
    Stan
  • George Dean
    May 10, 2019 at 7:10 pm
    Hi Stan,
    I’m recording a test file based on your settings, and will see if I con duplicate your issue. Will report back soon.
    Hi Tyson, it appears that your thread is now going two different directions, your mov issue and Stans’ mp4 issue. I hope we can keep this straight!
  • George Dean
    May 10, 2019 at 8:02 pm
    Hi Stan,
    I cannot duplicate your Pan & Crop crash. However, it’s not that uncommon for so many different other reasons, but was worth the effort to eliminate. Here are the specs of the test source media I used which are very silimar to yours:
    General
    Complete name : I:\DCIM\102_PANA\P1020242.MP4
    Format : MPEG-4
    File size : 3.97 GiB
    Duration : 5 min 58 s
    Overall bit rate : 95.1 Mb/s
    Encoded date : UTC 2019-05-11 00:25:31
    Tagged date : UTC 2019-05-11 00:25:31
    Video
    Format : AVC
    Format settings, RefFrames : 2 frames
    Codec ID : avc1
    Bit rate : 93.6 Mb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.451
    Stream size : 3.90 GiB (98%)
    Color range : Full
    Audio
    Format : PCM
    Codec ID : twos
    Bit depth : 16 bits
    Stream size : 65.6 MiB (2%)
    Other
    Type : Time code
    Time code of first frame : 03:48:00:16
    Bit rate mode : CBR
    I used Magix Vegas Pro 15 build 416, are you on the same build?
    Have you performed a full/factory reset? Hold down the ‘Ctrl+Shift’ keys while you double left click on the Vegas Pro desktop shortcut. In the small popup window, check the box ‘Delete all cached application data’, then left click on ‘Yes’. This will set all Vegas settings to their default installation values and delete the pesky cached application data which will sometime build up and cause Vegas Pro to do strange things.
    From what I have read this morning looking back, any issues with the GH5 files was based on the Hvec codec yielding 10 bit, but should have nothing to do with your 4:2:0 8 bit AVC recordings. I found no complaints about the GH4/GH5 mp4/LPCM files.
    Here are my system specs if you would like to compare them to yours…..
    Corsair Obsidian Series 450D ATX Mid Tower
    Asus X99-A II LGA 2011-v3, Intel X99 SATA 6 Gb/s USB 3.1/3.0 ATX Intel Motherboard
    Intel Core i7-6800K 15M Broadwell-E, 6 core 3.4 GHz LGA 2011-v3 (overclocked 20%)
    64GB Corsair Vengeance LPX DDR4 3200
    Corsair Hydro Series H110i GTX 280mm Extreme Performance Liquid CPU Cooler
    MSI Radeon R9 390 DirectX 12 8GB Video Card (driver 25.20.15011.1004)
    Corsair RMx Series RM750X 740W 80 Plus Gold power pack
    Samsung 970 EVO NVMe M.2 boot drive
    Corsair Neutron XT 2.5 480GB SATA III SSD – video work drive
    Western Digitial 1TB 7200 RPM SATA – video work drive
    Western Digital Black 6TB 7200 RPM SATA 6Bb/s 128MB Cache 3.5 data drive
    Bluray Disc burner drive
    2x 1080p monitors
    Microsoft Window 10 Pro (1809)
    Your VP15 crashes doing Pan & Crop, mine doesn’t, so I have listed as much as I can for you to determine what is different between our setups and possibly lead to a resolution. There are most likely many differences but I would be most concerned with the Vegas build number and GPU make, model, and driver.
    Have you also turned off your GPU in Preferences (Video tab), ‘GPU acceleration of video processing’, which may yield a better result to avoid the crash?
  • Stan Willis
    May 10, 2019 at 8:34 pm
    Hi George,
    Thank again for your time. I have the same 15/416 Vegas build as you. A single large 4k Samsung HDR tv as monitor. An earlier i7, 16Gb of Ram, video and Windows 10 (not pro) on separate SSD drives. An Nvidia 1060 GPU. I applied the NVidia creators update fairly recently so I would think my GPU driver is utd. I will try turning off GPU processing to see if it helps. If that is the cause I’ll probably stick with Resolve so I can use it.
    all the best
    Stan
  • Stan Willis
    May 10, 2019 at 8:41 pm
    HI George again,
    I should have said the factory reset method you describe doesn’t work for me but a few weeks back I deleted the cache files manually.
  • George Dean
    May 10, 2019 at 8:47 pm
    Hi Stan,
    Well, if there is anything else I can do, or making more confusing, please let me know. Good Luck with it.
    BTW, way back I started tinkering with Resolve 12.5 and last year I seriously and finally got into self-training with v14. Then I made the switch when v15 was released. Now I’m on the studio version and haven’t looked back, other than now I tinker with Vegas Pro to try and help others and some friends I have that are still using it. recently I jumped tot he v16 studio beta and it has been running very well actually and runs everything better than Vegas, so I understand your frustration and wish you well in what ever you decide to use.
  • Francois Pénzes
    May 11, 2019 at 3:02 pm
    Hi Tyson
    As for QT version 7.6.8 , it’s just trial and error. I just find that particular version to be the most stable with Vegas. I try to use it a less as possible.
    You also have to keep in mind that QT for PC is 32bit and it’s trying hard to work in an 64bit environment. You will be limited in what it can take. Your best bet is to convert your .MOV files to a more Vegas friendly format by using Handbrake or FFmpeg. Choose the end-use file type that suits your needs.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
Page 2 of 3
