Activity Forums VEGAS Pro Vegas 15, Titles & Text Problem
  • Vegas 15, Titles & Text Problem
    Posted by Tyson Onaga on August 13, 2018 at 5:53 pm
    Hello,
    Trying to use Titles & Text Fly In w/ R justified (or even L justified text).
    Using an animated Anchor Point w/ Center Right (or Center Left) to keep the text fixed on the R (or the L).
    However, in the last second of the animation, the text starts drifting R (or L).
    This looks stupid.
    Is this a bug — is there a work-around?
    – tyson
    Tyson Onaga replied 8 years, 1 month ago 2 Members · 2 Replies
  • Graham Bernard
    August 14, 2018 at 5:40 am
    [Tyson Onaga] “Is this a bug — is there a work-around?”
    Sorry Tyson – I can’t replicate. Working as I would expect without the anomaly you’re getting – sorry. ????
    My guess is that you MAY have an unfortunate, rogue KeyFrame introduced somewhere on the T&T Timeline Curves? Have you extended the Event length at some point in your editing? You could’ve gotten into a situ with an additional KF. I’ve done this in the past, it’s a real PITA. But, without us scrutinizing your Event and the T&T Timeline Curves it is going to be unrewarding guesswork.
    * Grazie
  • Tyson Onaga
    August 16, 2018 at 10:47 pm
    I had tried to Copy an object and Paste (as a new instance, not a reference) …. then change the values.
    Apparently, something went sideways.
    Creating a new Vegas Titles & Text object, changing the Animation (not the Preset), copying values from another instance of Vegas …. appears to work.
    Thanks for your effort Graham.
