Activity Forums VEGAS Pro Vegas 15 Pro Build 361 – After Update to 361 MP3 files Screech
  • Vegas 15 Pro Build 361 – After Update to 361 MP3 files Screech
    Posted by Brian Butte on June 6, 2018 at 1:02 pm
    I updated Vegas, opened a project and suddenly all of my MP3’s make a screeching noise. I know I can convert files to WAV format which works for my current project, but I have numerous projects with MP3 files so I need to find a solution that isn’t downgrading to the previous version of Vegas if possible (had the same issue updating to 216). Obviously the cause is related to the update, but I have no idea how to fix it. (Windows 10 w/ Nvidia GTX 980 card)
    Dhanen Moteuchi replied 8 years, 3 months ago 2 Members · 1 Reply
  • Dhanen Moteuchi
    June 9, 2018 at 4:30 am
    So, if you play mp3 on another player it sounds well? I guess you tested it already but, who knows. Maybe some has corrupted, but I don’t think that could be the problem. I should try to reinstall codecs to see if that solves the problem and assure you have installed QT. Hope it helps.
