Activity Forums VEGAS Pro Vegas 15 Default Plugins Not Working
  • Vegas 15 Default Plugins Not Working
    Posted by Martin Smilgsdrivs on July 28, 2018 at 10:52 am
    Hello,
    I have the default Vegas 15 plugins and I just tried adding the “Distortion” effect to an audio clip.
    Then this box popped up :
    The Plug-in ‘Distortion’ failed to load. Please make sure the plug-in is properly installed.
    Graham Bernard replied 8 years, 1 month ago 2 Members · 8 Replies
  • 8 Replies
  • Graham Bernard
    July 28, 2018 at 2:45 pm
    [Martin Smilgsdrivs] “I have the default Vegas 15 plugins”
    Go to Preferences and rescan VSTs. Try that and report back.
    * Grazie
  • Martin Smilgsdrivs
    July 28, 2018 at 5:35 pm
    Where in Preferences > VST effects can you rescan VSTs ?
  • Graham Bernard
    July 28, 2018 at 6:17 pm
    [Martin Smilgsdrivs] “Where in Preferences > VST effects can you rescan VSTs ?”
    It’s under one of the Tabs.
    Here, VST:
    * Grazie
    July 28, 2018 at 6:34 pm
  • Graham Bernard
    July 28, 2018 at 6:39 pm
    See the Rescan button? Rescan. It’s what I do.
    * Grazie
    July 28, 2018 at 6:51 pm
    Well, there isn’t a re-scan button, but there is a refresh button. When I press it nothing really changes. No pop up box and the effects still don’t work.
  • Graham Bernard
    July 28, 2018 at 6:52 pm
    Works for me. I’m out of ideas.
    * Grazie
  • Graham Bernard
    July 29, 2018 at 6:34 am
    [Martin Smilgsdrivs] “I have the default Vegas 15 plugins and I just tried adding the “Distortion” effect to an audio clip.”
    Well Martin, I’ve just checked it on my rig and it is working:
    This suggests that you have a local issue. Are you using the latest Build 361 of VP? You try a reinstall of VP or the Factory Reset – this would mean you’d loose all your settings – up to you. In my experience something has lost its way to your VP GUI and is wandering hither and thither….
    * Grazie
