Activity Forums VEGAS Pro Vegas 15 always shuts down”improperly”
  • Vegas 15 always shuts down”improperly”
    Posted by Robert Maier on October 1, 2020 at 3:30 pm
    Every time I restart my computer after working several hours with Vegas Pro 15, I get a message that because it shut down improperly, I have to reboot an autosave version and rename it. What do you think the problem is?
    Francois Pénzes replied 5 years, 11 months ago 3 Members · 3 Replies
  • Steve Rhoden
    October 1, 2020 at 4:05 pm
    Probably because when you close down Vegas, its always still there running in the background, and you have to go in the “Task Manager” to fully kill the process. This is a well known memory leak problem for a looong time. I personally usually use a script called KillallVegas to keep this minor issue at bay. But the good thing is that now, the issue is no longer present in Vegas Pro 18…… So you can try one of those two solutions!
  • Robert Maier
    October 1, 2020 at 5:20 pm
    Thanks Steve, good advice.
  • Francois Pénzes
    October 1, 2020 at 9:23 pm
    Hi Robert
    Adding to Steve’s comment, you will find the script here:
    https://tools4vegas.com/kill-all-vegas/
    Cheers !
