Activity › Forums › VEGAS Pro › Vegas 14’s MP3 files became corrupt.
  • Vegas 14’s MP3 files became corrupt.
    Posted by Ricardo Assad on July 15, 2018 at 4:32 am
    Greetings.
    Recently my HDD broke and I had to reinstall Sony Vegas. However, now every file in MP3 format sounds like garbled audio or just muted. Before replacing the disk it worked flawlessly. The same MP3 files work correctly in any audio playback/manipulation software, however. Other formats work correctly in Vegas, but converting all files used in the project would not be preffered because there are many, and it would take time and space in disk. Is there any solution?
    I’m running Vegas PRO 14 (build 270) on a Windows 10 Pro 64-bit, audio drivers are installed.
    Thank you kindly.
    EDIT: I managed to find the issue – the AppData folder, which I made a backup of, was causing a codec conflict in the software, causing the incorrect MPEG codec to load. I deleted the Vegas PRO appdata folder located in Local and restored the configurations, and now it works.
    Ricardo Assad replied 8 years, 2 months ago 2 Members · 5 Replies
  • Graham Bernard
    July 15, 2018 at 5:08 am
    [Ricardo Assad] “I’m running Vegas PRO 14 (build 270)”
    Hi Ricardo, you might wish to consider installing the latest Build 361. See if that improves matters.
    * Grazie
  • Ricardo Assad
    July 15, 2018 at 6:28 am
    I might consider that later, the cost is a bit sour currently considering that I edit videos as a hobby instead of using it as a profession. Thanks for the suggestion though.
  • Graham Bernard
    July 15, 2018 at 6:52 am
    [Ricardo Assad] “I might consider that later”
    My mistake Ricardo! I meant the latest Build for your VP14. Is that build the latest?
    * Grazie
  • Graham Bernard
    July 15, 2018 at 6:58 am
    I just saw your Editted Original Post:
    “EDIT: I managed to find the issue – the AppData folder, which I made a backup of, was causing a codec conflict in the software, causing the incorrect MPEG codec to load. I deleted the Vegas PRO appdata folder located in Local and restored the configurations, and now it works.”
    Good to know….Good to know …..
    * Grazie
  • Ricardo Assad
    July 15, 2018 at 8:16 pm
    Yes! I wasn’t expecting the issue to be there. I made a backup of everything to ensure that no data would be lost, I did not imagine that the issue would be there. Hopefully other people who comes across the same issue can try that out and fix it.
