Activity Forums VEGAS Pro Vegas 13 will not render .mov – “message missing” – what can I do to fix it?
  • Vegas 13 will not render .mov – “message missing” – what can I do to fix it?
    Posted by Jason Merrill on August 13, 2014 at 7:29 pm
    title says it all.
    .mov just throws up an error message…
    Stephen Mann replied 12 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    August 14, 2014 at 1:38 pm
    Do you have Quicktime installed?
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Jason Merrill
    August 14, 2014 at 2:41 pm
    yes, I do.
  • Stephen Mann
    August 14, 2014 at 3:01 pm
    My car won’t start. What can I do to fix it?
    All snark intended, you ask a question that could have a hundred answers because you aren’t telling us anything about the project: What’s the source media, which “render as” template are you using, had it worked before, is GPU support enabled, do you have enough hard-disk space, have you recently changed any hardware, software or drivers?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jason Merrill
    August 14, 2014 at 3:03 pm
    well, how am I supposed to know what to look for if I don’t ask? 🙂
    the source media are mp4 and mov files, 1920*1080 from canon DSLR, 29 fps.
    no GPU processing, plenty of HDD space.
  • Steve Rhoden
    August 14, 2014 at 5:00 pm
    Well try reinstalling Vegas, and make sure its the newest version (Build 373).
    And if you have any Codec packs installed, un-install them first.
  • Jason Merrill
    August 14, 2014 at 5:37 pm
    already did that. No good.
    How do I know what codecs are installed and how to I alter that?
  • Stephen Mann
    August 15, 2014 at 3:03 am
    Did you ever install the K-Lite Codec pack?
    What version of Quicktime do you have?
    Did it ever work before?
    Do other renders work with the same media?
    What CODEC are you trying to render with? (MOV is just a container.) Alternately, what “Render As” template are you using?
    Steve Mann
    http://www.mmdv.com
