Activity › Forums › VEGAS Pro › Vegas 13 STILL giving me grief!
  • Vegas 13 STILL giving me grief!
    Posted by David Pendry on November 20, 2014 at 12:08 pm
    Does anyone know what an ‘mxf.sfl’ file is, and why Vegas 13 is rendering DV into it!??!?!
    I have been trying to get this to work for 3 days now, and am just about to shoot myself in the head. (just so long as the gun doesn’t come from Sony it might work!)
    I am SO annoyed by Sony’s inability to create something that works.
    Ever tried to contact them? Fun, isn’t it?!
    Giving up on this completely.
    I’ve had enough.
    Steve Rhoden replied 11 years, 10 months ago 4 Members · 4 Replies
  • Andrew Lenczycki
    November 20, 2014 at 6:22 pm
    I’m not at home (where my Vegas machine is), but I believe the mxf.sfl file is created by Vegas when rendering but is NOT the output file you want. If I’m not mistaken, that is the file that Vegas uses to display the audio waveforms for your video.
    You didn’t give a lot of info on what type of file(s) you are trying to render or what format you are trying to render them to. One thing to watch out for: Your rendered output file will go into the folder you last rendered into, unless you specify otherwise. This may be important if you are rending output to (what you think is your current folder), when it’s actually going to the “last used” folder. As an example: I keep all my given files for a project in a top level folder with the year and project name (i.e. 2008 Austin Lake). If I last rendered a file to that folder (because that’s what I was working on), then the next time when I start a new project folder (say 2014 Varsity Football) and render output, it will go into the Austin Lake 2008 folder rather than the folder I am now working in (Varsity Football 2014). You must make sure and navigate to the EXACT location you want your output put into when you give the output file its file name, or Vegas will output it to the folder last used. I don’t know if that’s what’s happening here or not (not enough detail given).
    I understand your frustration – for anyone to be able to help you, give as much detailed info as possible including what you are trying to do, and what you are/are not getting.
    Andrew Lenczycki
  • Mark Thompson
    November 21, 2014 at 11:58 am
    Hi David,
    they are DV are they?
    I didn’t know what they were but I don’t think you need to worry about them. They don’t come from the camera but Vegas creates them when it imports/sees the MXF file. Vegas saves metadata there but they seem too big for just that.
    I ignore them in my workflow, which really means Vegas is using them for its own purposes.
    How are they causing you problems?
    mark
  • Steve Rhoden
    November 22, 2014 at 9:10 pm
    Yes you are frustrated, but for us to help you,
    you have to give us more detailed info on your
    workflow, output format, sources etc…
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Steve Rhoden
    December 1, 2014 at 1:26 pm
    I guess!
