Activity › Forums › VEGAS Pro › Vegas 13 FX mask
  • Vegas 13 FX mask
    Posted by László Kovács on August 5, 2016 at 11:58 am
    One interesting new feature of Vegas 13 is that It’s possible to mask effects.
    However I did not found the way to apply an effect to the whole image, and mask another effect.
    (I may overlook something)
    To make it clear: I almost always have to tweak the image in color/contrast, etc, usually color curves, sometimes color corrector.
    (Colormatch looks promising, as well :))
    So let’s say, I need a color curve for the whole image, and a blur for a portion of it. Is that possible with only one clip/track using masking effects?
    Otherwise I have to do it the old way using 2 tracks and masking the top one…
    Thanks …
    László Kovács replied 10 years, 1 month ago 3 Members · 6 Replies
  • John Rofrano
    August 5, 2016 at 1:28 pm
    Applying a Mask to the FX is All or nothing. You cannot just have it apply to some FX and not the others in the chain. This is unfortunate I agree.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • László Kovács
    August 5, 2016 at 1:31 pm
    Thanks, so I’m not that blind that couldn’t find the way.
  • Graham Bernard
    August 5, 2016 at 2:33 pm
    Put in another kf select the fxs you want then apply another with the fxs you want or not want. Won’t that work?
    * Grazie
  • László Kovács
    August 5, 2016 at 3:03 pm
    I’m not sure I understand what you mean. What is a “kf”?
    For what I want to achieve in the above example, I need the clip on 2 tracks. The topmost has all the effects, the below one only the effect(s) I need to apply to the whole image. Then I crop/mask the topmost clip, so that only a portion of it is visible, on which I need the “masked effect”.
    I used to do this technique many times with Vegas 10.
    Now I’m just exploring my new Vegas 13, and at a first glance, this effect masking thing looked promising for tasks like this, and there would no need to double the clip.
    But seems I was wrong, it does not work this way 🙂
    Kind regards
  • Graham Bernard
    August 5, 2016 at 3:19 pm
    KF = Key Frame
    * Grazie
  • László Kovács
    August 5, 2016 at 7:51 pm
    [Graham Bernard] “KF = Key Frame”
    Oh, I see. So I understand what you mean.
    And no, keyframes are for changing some parameters in time.
    This is something different.
    Kind regards.
