vegas 12 with 720p 60 fps
Posted by Howard Steiger on February 1, 2014 at 2:02 amI use a gh2. I film in 720p 60fps. I want a master mpeg that is hd. I see no option in render settings for 60 fps only 30. when I try to go custom and change to 60 it errors out. workaround? any help appreciated Thankx
Howard Steiger replied 12 years, 7 months ago 3 Members · 7 Replies -
Stephen Crye
February 1, 2014 at 3:20 amHi;
I have a GH3 and do this all the time, but at 1080p. Don’t see why it would not work at 720p. You may have to play with Smart Resample, though.
Here is a screen shot of the Frame Rate drop down that lets you pick “60p”
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
Howard Steiger
February 1, 2014 at 4:19 amThank you for your reply! My final delivery is standard dvd but I want to keep an hd file in 720p in case someone wants blu ray. I find it odd that this is an internet setting? Will this produce same quality as an mpeg2 does for dvd?
Norman Black
February 1, 2014 at 5:14 am[Howard Steiger] ” I see no option in render settings for 60 fps only 30. “
What render as Encoder and template?
Sony AVC certainly does have 60p (59.94).
Mainconcept AVC does not have it in the drop down but you can easily enter the value.
XDCAM EX does have 60p
Mainconcept MPEG-2 has 60p. -
Stephen Crye
February 1, 2014 at 5:24 amAFAIK DVD video has a max 29.97 fps using 60i. That is why the double-rate “60p” is not available in the DVD tempplates.
One of the pros on this forum can give us the final word.
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 12GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
Howard Steiger
February 2, 2014 at 2:45 amYes mpeg2 does offer this but only if your rendering for 720×480 for dvd. I want a an hd master file from 720 p for maybe blu ray later
Norman Black
February 2, 2014 at 4:57 pmI am able to create a Blu-ray 1280×720 59.94 template in Mainconcept mpeg-2.
Since no 720 Blu-ray template is predefined for MC mpeg-2, I start with the 1080p24 one and change the frame to 1280×720, rate to 59.94 and I-frames to 30.
Howard Steiger
February 17, 2014 at 7:14 pmwhen i do this I get an error code it wont let me render in that template
