Activity › Forums › VEGAS Pro › Vegas 12 render problem
  • Vegas 12 render problem
    Posted by Greg Warren on June 3, 2014 at 2:40 am
    Hi All. I’m working on an project rendered to Blue Ray. The playback in DVDA is stuttering a lot with the camera moves. I found a thread with a google search to turn off the GPU accelerator and that did not help. I did the render with the GPU on and off and am still getting the jitter. Any help would be appreciated!
    Thank you!
    Greg
    John Rofrano replied 12 years, 3 months ago 3 Members · 5 Replies
  • John Bolton
    June 3, 2014 at 4:03 pm
    Can you explain a bit more what JITTER actually looks like. Do you mean like fuzzy or interlace issues.. Can you post a small clip of the problem or post a screen shot of the JITTER….
  • Greg Warren
    June 3, 2014 at 4:53 pm
    John
    I’ll try to post a clip. The issue for example is when the camera pans left to right the video stutters and it not a smooth looking move. This is after the rendering. When I’m working on the timeline in Vegas the footage is smooth. It looks like the camera is “jerky” for lack of a better term.
    Greg
    Greg
  • John Rofrano
    June 4, 2014 at 1:58 am
    [Greg Warren] “The issue for example is when the camera pans left to right the video stutters and it not a smooth looking move.”
    Are you rendering to a lower frame rate than the source video? This could cause stuttering if you disabled resample and the movement is too fast.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Greg Warren
    June 4, 2014 at 2:10 am
    John
    I think I resolved this by using the Sony render settings instead of Main Concept. The footage was smooth when I reviewed on DVDA. Thank you!!
    Greg
  • John Rofrano
    June 4, 2014 at 1:04 pm
    [Greg Warren] “I think I resolved this by using the Sony render settings instead of Main Concept. The footage was smooth when I reviewed on DVDA.”
    Very interesting. Glad you figured it out.
    ~jr
