Activity › Forums › VEGAS Pro › vegas 12 pro render mxf with no comprassion needed
  • vegas 12 pro render mxf with no comprassion needed
    Posted by Eddy Lizi on March 7, 2013 at 11:22 am
    hi all,
    i am using vegas pro 12,
    i have a footage of:
    Video: 00:07:19.200, 25.000 fps interlaced, 720x576x32, DVCPRO
    Audio: 00:07:19.200, 48,000 Hz, 16 Bit, Stereo, MXF Audio
    Folder: C:Program FilesSonyVegas Pro 12.0FileIO Plug-Insmxfp2
    Format: Panasonic P2 MXF
    Version: Version 12.0 (Build 394) 64-bit
    my problem is when i am rendering,
    i tried all codecs and customized some myself and still
    when i am rendering it compress the footage
    all my other projects are show “no compression is needed” an it is rendering much faster
    how can i render without compression???
    thank you
    Paul Beller replied 13 years, 6 months ago 4 Members · 13 Replies
  • 13 Replies
  • Steve Rhoden
    March 7, 2013 at 11:32 am
    For supported media, you can only render without compression
    if no effects are on the clips and if you are rendering out
    to the exact specification and format of the clip thats on
    the timeline.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Eddy Lizi
    March 7, 2013 at 11:50 am
    thx for reply steve,
    i am well known of vegas pro
    and i know when there is need for compression
    and that is my problem
    i just change the clips order, nothing else and still
    and i did try multiple template and codecs
    any other ideas?
    thanks
  • Steve Rhoden
    March 7, 2013 at 1:40 pm
    Looking back on your post, i dont think vegas offers
    No recompression support for the new Panasonic P2 MXF format.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Mike Kujbida
    March 7, 2013 at 1:44 pm
    The list of formats that won’t recompress is fairly limited.
    I posted a screenshot from the manual in the recent no recompression required thread.
  • Eddy Lizi
    March 7, 2013 at 3:04 pm
    thx a lot guys:)
    mike, the manual does say dv mxf will NOT be recompress
    and still it compress it
  • Mike Kujbida
    March 7, 2013 at 3:08 pm
    eddy, just to clarify, no recompression only works if your source and destination files are identical.
    i.e. it won’t work by going from an unrelated format to one on the list.
  • Steve Rhoden
    March 7, 2013 at 6:23 pm
    Again, your renders need to be exact as that of the source
    file eddy.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Eddy Lizi
    March 7, 2013 at 7:39 pm
    again i am very familiar with vegas codec and my files as i mention are untreated i just rearrange the order of them that is all
    the settings of the project and the render are the same as the footage
    so the only thing i can assume is what you guys said
    THAT SONY VEGAS DOES NOT SUPPORT P2 MXF UNCOMPRESSED RENDER
  • Mike Kujbida
    March 7, 2013 at 8:01 pm
    [eddy lizi] “so the only thing i can assume is what you guys said THAT SONY VEGAS DOES NOT SUPPORT P2 MXF UNCOMPRESSED RENDER”
    P2 MXF isn’t on the format list that I linked to so you are correct.
  • Eddy Lizi
    March 7, 2013 at 8:58 pm
    thx again mike,
    if you look on the list of files that don’t require recompress you will see
    “DV MXF”
    i am confused
