vegas 12 dvd off timeline burn
Posted by Howard Steiger on May 30, 2014 at 5:15 ami tried loop playback. it renders then prepares dvd for burn but fails to burn on multiple recorders. can it be done and if so how? thanx
Howard Steiger replied 12 years, 3 months ago 2 Members · 2 Replies -
Graham Bernard
May 30, 2014 at 6:04 am_______________________________________________________________
[Howard Steiger] “but fails to burn on multiple recorders.”
_______________________________________________________________What do you mean Howard? What do you want to do?
Is it:
A] Do you want to simultaneously burn to MANY Burners?
. . or is it . .
B] Are you getting failure to swapping to other Burners?
If it is “A” then I have never seen read and heard of that as being an option directly from the Vegas Timeline. If it is “B” then you;d need to investigate each and every Burner. Yes?
Sorry, I’m not being very helpful.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Howard Steiger
May 30, 2014 at 6:16 amvegas 12 has a known issue of burning dvds off timeline just wanted to know the fix it fails to work
